TXC Kickstand
Discussion in '4 Stroke' started by lesrsz28, Jan 20, 2009.
  1. superneil21 Husqvarna
    TC
    Yamaha
    about $20 using premium lol
  2. Reddog Husqvarna
    Michigan
    So after a few to many crashes, I needed to do some repair/retrofitting.
    First I made a tab to weld to the frame.
    Then I cut off some of the boss on the back side of the stand.
    Tacked this in place and checked all the clearances, and then welded it solid.
    This winter when I tear the suspension apart to clean and grease it, I will reattach the lower chain roller. :cheers:
  3. TXC&KTM Husqvarna
    Costa Mesa, CA
    yeah, my kickstand rubs too...and I've found that I DON'T GIVE A DAMN! Just ride....
  4. wingnut Husqvarna
    Barrie, Ontario
    Yeah mine rubbed through the finish on my 2009 txc 250 after the first ride. That was after I added 4 washers to the lower mount.
    I removed those then switched the kick stand to mount on the outer side of the black bracket, then finally bent it out a 1/4".
    Now all is well:cheers:
  5. Bobby Husqvarna
    Woodstock, GA
    '13 TXC310Rx2,
    G450X, HP2E, 10 R12ADV, GasGas280
    The inconsistancy in frame dimensions for both 08 and 09 production years is what prompted HSQ IT to change the supplier for 2010 models. No doubt some brackets will need alot of shimming while others none. This phenomenon is also evident if you look at the inside of the left frame riser just inside the footpeg next to the chain. With 40+ bikes I've checked out personally, some the chain just barely rubs the frame and others have tons of clearance. No rhyme or reason, just incosistancies.
    What I will say is I'd grind and weld on my TXC frame before bolting that monstrousity to it,........no offense.
  6. Motosportz CH Sponsor
    That's what we have struggled with as well.
  7. Bendage Husqvarna
    TXC 450
    [IMG]So I know this thread is old but I'm in real need to find a kickstand. I bought a TXC 450 Super Moto from Craigslist and its a pain parking this thing against a wall wherever I go. It appears that a MotoSportz kickstand was once installed on it as the bracket to the frame still exists but the kickstand is gone. Can't find a direct replacement.
    Any advice would be greatly appreciated.
  8. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    The direct replacement should be available through trailtech...
    Later,
