Updated TPS/EFI Reset 449/511
Discussion in '4 Stroke' started by Tinken, Nov 14, 2012.
  1. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  2. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Have you added a Jorgenson clamp to your 511? Trying to draw eyes away from the shiny aluminum block perhaps?
  3. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Haha, that's part of my solar cooker...
  4. jeffrodub Husqvarna
    Etiwanda, CA
    2011 TE 449
    CR250, 250R ATC
    Is it safe to assume that at the end of step one you shut off the engine?
  5. philfy20 Husqvarna
    Australia
    SMR 511 2011
    I am having to do this reset every month or so. Is this normal or could there be underlying issue? Have checked the the throttle cable and all looks fine and smooth.
  6. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Not normal. Why are you having to do the reset?
  7. philfy20 Husqvarna
    Australia
    SMR 511 2011
    I'm having to do the rest as it seems as the throttle is stuck open. I would accelerate and then of the throttle completely and it still revs pretty high (feels like stuck 1/4 open throttle) even with the clutch pulled in completely. Sometimes it got that bad i have been going 60 Km/h and slowing down to stop at lights and even when am at the lights stopped its still reving way to high. Have fiddled around the big brass air bypass screw and its spot on to what the thread suggests. As soon as I do the reset it is fine for a few weeks and slowly gets worse and worse.
  8. Motosportz CH Sponsor
    Very odd. The reset fixes it for a while? If so how long?
  9. danny318 ___________
    MA
    '13 TE449
    TTR230, '72 CT90
    Maybe try grounding the throttle body/tps
    Tinken likes this.
  10. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Sounds like a bad or failing throttle position sensor to me.
    oregonsage likes this.
  11. Apri11 Husqvarna
    Queensland
    2016 FE 450 / 2013 TE 511
    2011 Aprilia RSV4
    Won't hurt to try it like danny318 suggested, at east temporarily anyway. I was having the opposite issues, constantly would not idle. I had TPS rest approximately a dozen times, although fixed it temporarily it would always play up again at the most crucial moment. I grounded the throttle body and also sealed the ECU plug with mastic tape as I suspected water ingress within the plug/connections playing havoc (I routinely wash after every ride). I haven't had the problem since, can't say though whether it was soley either the grounding of the throttle body fix or the ECU plug mastic idea, maybe both? Like Tinken stated, a failing throttle position sensor is quite possible.
  12. Normann Husqvarna
    Moscow/Valdai, Russia
    TE449 MY2012
    I'm having same, only if engine very hot. I think, that's mixture problem. Airbox is too hot - mixture is too rich. May be I'm wrong.
  13. fasteer Husqvarna
    Calgary, Alberta
    2017 701 Enduro
    Sherco SEF300 (for sale)
    Three hours of singletrack last night and the 511 with the Zip-Ty remap (#3) is worlds better than before.
    Even on botched log hops when I was sure it would stall- it didn't. Pulls like a John Deere from idle.
    Thanks again Tinken.
    philfy20 and Motosportz like this.
  14. inachun Husqvarna
    smr511
    Had to do a reset/ adjust bypass today due to constant stalling then after 5 minutes it started to overheat and the throttle would not shut off. Had to use the kill switch twice as the engine would start by itself after the first attempt. Pretty annoying - gave up and went home. Will have to look at the cables to see if that helps? Was running great the last couple of months.
  15. nonferrous Husqvarna
    Auckland, New Zealand
    SMR511
    RMZ450
  16. nonferrous Husqvarna
    SMR511
    RMZ450
    Just wanted to say thanks very much for this thread - I was unhappy how the bike was running until I did the TPS reset and air bypass adjustment - these bikes are awesome.
  17. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    You should upgrade your ecu map set to #3 if you haven't already done so.
  18. nonferrous Husqvarna
    SMR511
    RMZ450
    cheers Tinken - Mine is the only SMR in NZ which I imported from Australia. I called a couple of Husqvarna dealer workshops and they didn't know what I was talking about. The NZ importer did bring in the 449 TE & TC models so you would think they should have the info - I also called a BMW dealer and they said they will look into it as well.
  19. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    The alternative and better option in my opinion is to add the powercommander5.
  20. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
