125-200cc Uptite 167
Discussion in '2 Stroke' started by Kevin_TE250, Nov 3, 2010.
  1. motocrossmr Husqvarna
    New Jersey
    '15 TE300
    '05 PW80, '12 KX 65
    dfeckel,
    Thanks for the info! I looked at part numbers and saw that the stator for an '08 vs. '09 CR125's have different part numbers. Being that you have a '08 CR and I have a '09 WR I am wondering that if I buy the same parts as you did......will it fit on my '09? The cranks are both the same so I cant see it not fitting. What year CR250 harness did you end up buying? I looked for the part number listed but couldnt locate it. Basically you just have to switch out the wiring harness right? I need to swap my coil and stator as well. I just want to make sure all my parts work together before purchasing. Any insight would be awesome. And by the way.....Im on the list for Walts 165 kit as well! Thanks - Matt
  2. NWRider Husqvarna
    The CDI is in a different location 09 and up so the wires are longer. That is probably why the part numbers are different. I used older parts on my 09 but I had to cut and extend the wires.
  3. motocrossmr Husqvarna
    New Jersey
    '15 TE300
    '05 PW80, '12 KX 65
    Cool,
    thanks for the info NWRider. My local dealers are closed today so I will make some calls to get prices tomorrow.
  4. dfeckel Husqvarna
    Medford, NJ
    You betcha, Rich!
  5. Vinduro Husqvarna
    Mississippi
    I put on my UPTITE 167 kit tonight. I was shocked on how clean my pipe and exhaust port and power valves were. Just a touch of carbon on piston crown. NONE at all on head. That is with my stock 144cc topend on my 2011 WR150. I have been running 1 gallon of Sunoco 110 race gas to 4 gallons of 100LL AvGas. Maxima K2 oil mixed at 40:1. My crank was soaked in oil when I pulled the top end. Clean burning oil ! I also use an ounce of StarTron Enzyme treatment to 5 gallons of fuel also. Stabilizes the fuel for up to 2 years and seems to make it burn more efficiently. I will crank it tomorrow. I was going to put on a 14T front sprocket but the one that was sent me was a 8 spline instead of a 12 spline sprocket. I plan on breaking the bike in next weekend working the Perry Mtn. Tri Sanctioned Shootout Hare Scrambles.
  6. Husqvarna125 Husqvarna
    Illinois
    2014 TE250, 2015 TE200, 1984 WR 400
    I would really like to hear your opinion and settings. I tried it and could not get it where I liked it. It runs good down low and it runs real good up top. I just could not get it to transition fast enough (from low to high) I didn't have enough time to play with different settings. I had a CR ignition with a 38 kehin carb. My guess is it needs a different pipe to really run right. Again interested in your report. I went back to the WR 125.
  7. Vinduro Husqvarna
    Mississippi
    Runs OK, Just not what I expected. I can tell more after I put on the 14T sprocket. Idles good. Seems good power but I had my 150 (144cc) running great. I am also running a 36mm Keihin. Bike idles good and jetting seems good. I think Walts kit keeps the crank compression up which will help develop more power. Walt also likes a different pipe. ANYWAY, Not making my judgement untill after I regear and do more riding.
  8. Vinduro Husqvarna
    Mississippi
    Think I will try the KTM 200SX pipe that Walt is talking up. It may just wake the 167 up.
  9. TROFFER88 Husqvarna
    Camas Wa
    These kits really need exhaust to run right
  10. CelticDude Historically Fast!
    x
    I rode Walt's bike with the 167 kit and it was good for him but not for me. Huge power on the bottom and midrange and then nothing. I love my 144 with Walt's powervalve spring kit! :banana:
  11. justplayin Husqvarna
    SNJ
    What spring combo did you settle on?
  12. CelticDude Historically Fast!
    x
    I'm running the large white spring with the small green one. Very smooth transition into a kick butt top end. Very fun to ride. I think the RB Designs carb mod makes it possible to run any spring combo you like.
  13. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    You would be amazed at the memory detail George has on jetting 2st bikes. Some guy came in that had an 82 500 and thought it had a Bing. George set him straight on how to jet his Mikuni (no, not a Bing) and coached him on tricks to starting it with all the relevant reasoning (and experience) behind the techniques and modifications done to the needles. Of course when you can make a ring out of barb wire, you probably are some sort of shaman already.
  14. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    Uptite bored my 02 to a 195 back in 03.....
  15. wallybean Mini-Sponsor
    Montana
    That would require a 67.5 mm bore which is into the head o-ring. Did he sleeve it to get it that big or did you stroke it too? With the 62.5mm bore it would require a 9mm increase in stroke. Just curious how he got it that big.
  16. racemx904 Husqvarna
    owenton, ky
    I have to put a spacer under the cylinder...dont remember what piston I was running...seems like a YZ but cant remember...
    but he did sleeve it and it was not a Chrome bore...
    boy it ran good too....
  17. Vinduro Husqvarna
    Mississippi
    Rode the 167cc some this weekend. Had to drop the main down from a 175 in my 36mm Keihin down to a 170. It would blubber on the main just before cleaning out otherwise. It definely needs taller gearing. I put on a worn 14T just to test with and couldn't tell a difference until I got into the upper gears. Halls was out of front sprockets , I ordered a 13T and a 14T from Kelly at Motosportz. I am putting a Moose 50T on the rear. I was running 13/52 on my 144cc top end.
  18. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    Why does it need taller gears? How does it compare to the 144?
  19. Vinduro Husqvarna
    Mississippi
    Why taller gears ? Makes that much more torque. I changed from a 13t to a worn 14T and couldn't even tell difference until I got into the upper gears. And still felt it needed taller gearing. Not a lot of difference in power on top but pulls a bit harder on bottom and mid. Just like you would expect with a 175 over a 125.
    Year & Bike Model = 2011 WR150 with Uptite Husqvarna 167cc kit.
    Carb = 36mm Keihin PWK A/S from 2011 KTM 150XC
    Pipe & Silencer = FMF Fatty WR125 pipe / FMF S/A silencer (going to try a modified FMF KTM 2003-04 SX200 pipe)
    Other engine mods = Exhaust spirngs Stock / silver.
    Premix ratio & fuel type = Maxima K2 @ 40:1, 100LL AvGas / 110 Sunoco race gas mixed 4 gal AvGas to1 gal Race Gas.
    Temperature range (deg F) = 65
    Elevation (feet) = 300ft. to 1,700ft ASL
    Main jet = 170 (144cc = 175)
    Pilot jet = 35
    Needle = NOZH (NOZI stock) (slightly richer needle so I could run on #3 position and keep more needle in needle jet.
    Clip position = #3 NOZH richer than stock NOZI #3
    Air screw setting = 3 (144cc = 2 3/4)
    Slide = 6.0 (stock 7.0)
    CHECK YOUR FLOAT SETTINGS. Mine was too high and overflowing when you hit bumps or slightly leaned the bike over. Set Keihin at 14mm
    No bogs now gone. 21mpg.
    Gearing 14T / 50T Parts Unlimited Xring Chain.
