All 2st Vertex or Wossner Piston??
Discussion in '2 Stroke' started by JDJ, Oct 23, 2013.
  1. Chris D'Angelo Husqvarna
    2007 Husqvarna WR 250
    2006 Honda CRF 450
    Hey guys, I'm running a 2007 WR 250...I've owned the bike since 08 and I'm pretty sure it's original everything. The bike has treated me very well, with good maintenance and no problems.
    Anyhow, I'm rebuilding top end, and researching which piston manufacturer to go with, this thread has been very helpful!
    The stock specs say that the bore and stroke are: 66.4 x 72mm. I'm leaning towards the wiseco piston kit, 66.40mm.
    I'm just worried, I want to order the right piston kit...any advice?
  2. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    I'd like to know how you work out which piston size to order as well. A. B. or C.
    There are manufacturers clearances but how to measure without piston?.
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Measure the cylinder bore diameter with a dial bore gage. This will give you the most accurate measurement and then you can order the appropriate piston. Any decent machine shop will have a dial bore gage and if you bring your clean cylinder to them measuring it will take less than 5 min.
  4. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    The cylinder size (A/B/C) will be stamped on the outside of the cylinder.
  5. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Kyle,
    Where is your cylinder stamped? I have looked mine over in the usual places and it appears I have an unstamped cyl. on my 09 WR250.
  6. rancher1 Husqvarna
    WA
    Sometimes the stamping is on the bottom of the cylinder on the base gasket surface.
    shawbagga and Kyle Tarry like this.
  7. rancher1 Husqvarna
    WA
    The piston is also stamped if you clean it.
    Kyle Tarry likes this.
  8. rockdancer Husqvarna
    The piston sellers say measure and then make your own assessment as to which size you need Eg ebay
    So not sure what tolerance is recommended
    Mine has a c stamped on underside And measures 66.15 - with callipers - hard to get exact
    Piston seems to be 66.05
    Is C largest?.
    Should a well used cylinder be honed ?
    cheers
  9. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Yes, but but you'll get all kinds of answers, from no, to just use scotchbrite, to honing it will hurt it, to don't lube your chain because its bad for it.
  10. Motosportz CH Sponsor
    No, never hone a plated cylinder. IMHO and many engine builders I have spoke to. It can be done but you need to fixture it right, have the right equipment like an expensive diamond hone and know how to use it. Otherwise you will just destroy stuff.
    also don't lube an o-ring chain, it is bad for it. :)
  11. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    s%#t stirrer!^
  12. MotoMarc36 Husqvarna
    wisconsin
    Many. Too many.
    Lol I was stirring a bit, too!:busted: All good, and a polarizing topic. Bottom line is you need a crosshatch to properly hold and retain a barrier wall of oil. If it is shined away, it should be honed. If you feel unsure, let a professional shop do it. Here are some references on the topic:
    http://www.nzcylinders.com/Cylinder honing.html
    http://www.flexhoneblog.com/2012/11/the-flex-hone-for-niaskil-engine.html
    Here's Millenium Technologies, employer of Eric Gorr, and platers for most of the top race teams. Notice the "light hone only" and "deglazing brush" in their price list. Call them, I promise they know more on the topic than any of us.
    http://www.mt-llc.com/cylservice.php
  13. rockdancer Husqvarna
    Thanks Marc good info
    I think I will start a new thread on my issues
  14. Chris D'Angelo Husqvarna
    2006 Honda CRF 450
    I had my cousin come to my shop, he works in a machine shop, we measured the cylinder diameter, it read 66.34 on a very accurate vernier (spelling?) and on another tool to be sure. So now I know the diameter of the cylinder wall...?
    The stock piston size is 66.40, is that ok?
  15. Chris D'Angelo Husqvarna
    2006 Honda CRF 450
    I'm thinking it should be fine, what do you guys think? What was you experiences with cylinder diameters vs. piston sizes to order?
  16. Chris D'Angelo Husqvarna
    2006 Honda CRF 450
  17. Chris D'Angelo Husqvarna
    2006 Honda CRF 450
    Also, I ran my fingers all around the cylinder walls, they are smooth throughout, but what about these discolouration? If it's smooth it should be fine or no?
  18. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    according to your measurements you have .06 clearance, is that what your spec is? i would clean it well in a crosshatch pattern with a scotchbrite and run it if it were mine..i dont have any long term reports about wossner but the 2 i have bought im very happy with. substantial weights savings, especially on the bigger cc models. im a fan of having a machine shop measure it with the proper tools as well.
  19. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Are you sure you don't have those two measurements backwards? You are saying that the piston is bigger than the bore and if so it wouldn't fit. If it was the other way around you would have .06mm or about .0024 inches which would be about right for a cast piston.
  20. MotoMarc36 Husqvarna
    wisconsin
    Many. Too many.
    Major oxymoron!! In precise measuring, we call vernier calipers " very near" calipers! For precise measurements of pistons, you need to use an outside micrometer. For the cylinder a dial bore gauge with a micrometer is preferred as Doug said. Verniers are good for setting oil heights, checking bolt lengths, verifying shim thicknesses, etc.
    Motosportz likes this.
