250-500cc Water in oil
Discussion in '2 Stroke' started by ks9mm, Jun 3, 2014.
  1. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I don't see any really good sources presently in an internet search this morning, but I do some firsthand experience with the old style inexpensive automotive coolant....in a truck. I was running this stuff in my truck for years. After about 13 years, my alternator quit working and I had it replaced. The technician who did the replacement, put a cooling hose back in place with the protective split sleeve in the wrong position. About a year later. I noticed that the car began to run hot one day, so I checked the coolant. It was quite low, so I filled the radiator and tank up, but noticed that there seemed to be dried coolant all over the alternator.. I discovered that the hose was touching the alternator in one spot, where the protective sleeve was split. The alternator had made a hole in the hose, causing coolant to spurt out right into the alternator. I pulled the brushes from the alternator, and they were completely worn out. I bought new brushes and put them in. The alternator worked properly for another three years, but then began to make some noise. This time, the bearings were shot. I have never seen bearings go bad in any alternator in any car that I have owned, and I put a lot of mileage on my vehicles. Brushes should not wear out in a year's time. I'm pretty sure that the silicates in the coolant caused the brushes and bearings to go south prematurely in the alternator. I don't run that "old style" coolant in my truck or any of my other vehicles anymore.
  2. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    Also check the sleeve that the seal rides on. Mine had a groove. I had no luck with aftermarket seal. The stock is double lipped and looks like it is in backwards, but it's not. Believe me.
  3. huskylove Husqvarna
    norcal
    1999 cr125 in progress
    Its all good the water will wash the engine nice and clean for ya....
  4. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    Dirt Dame, spraying coolant into your alternator may well have caused the brushes and bearings to wear out, but I'd hardly jump to the conclusion that it was specifically the silicates in that type of coolant that did the damage. Any type of coolant would probably make an alternator really unhappy.
  5. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Right out of my Honda CR manual.
    Kyle Tarry likes this.
