Water in swingarm
Discussion in 'TR650' started by Navelgazer, Apr 27, 2013.
  1. Next Strada Demolitionist
    Brevard, NC
    Sooooooooo, I called Europsort Asheville the other day about the water in the swingarm to see what the official word was from Husky NA. Lee, the service manager, has a call in to the national rep to find out the official "fix"--still no word on it, and my guess is that I will have to be persistent on this one.
    My guess is we (or dealerships) will all be drilling holes as others have done, but before I go putting holes in the swingarm I wanted to check with Husqvarna to see if they had a better fix before I go and void any warranty on the swing arm.
    Any dealer types (Bill?) heard anything official from Husky on this? Lee was saying that the more recent bikes appear to have drain holes drilled just below the mud-flap holes and mentioned that might be a good fix. Personally, I would want them drilled at the lowest point of the swing arm rather than the highest:excuseme:
    TerraCzar and Lekolite like this.
  2. socalrob Husqvarna
    BMW GSA
    I think the idea here is that as the bike is almost always under stonking accereration, and then full threshold braking, the water will be pushed to the front of the swing arm and drain out the holes under the mudflap at least 50% of the time.
    If, on the otherhand, the bike is being riden by a dottering old man, it is probably best to drill the holes in the bottom rear of the swing arm.
    Pretty sure Husky knows its market.:cheers:
  3. TerraCzar Husqvarna
    Ramona, CA
    2013 TR650 Terra
    Thanks for investigating, I agree, I am going to wait a bit as well(before drilling). I also would want the holes on the lowest point possible.
  4. krussell Strada Adventurer
    Portland, OR
    Strada (for sale)
    K1600 / Super Tenere
    It's been dry here for two weeks, and I've been in a lot of dusty stuff. There is water leaving both holes on my bike based on the streaks of mud in the dust leaving the holes. I'll work on the accelerate/brake fix for now. Hopefully it'll get figured out before the rain starts next fall.
  5. krussell Strada Adventurer
    Portland, OR
    Strada (for sale)
  6. johnb Husqvarna
    Northern Rivers NSW Australia
    tr650
    yz450f
  7. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    OK, I'll go drill some holes... you've convinced me.:thumbsup:
    Chuffa likes this.
  8. Navelgazer Husqvarna
    Peats Ridge
    Tr650 terra
    Yes
    That's was my solution JohnB, then sealed the mudflap and rode it for weeks, like 750 Ks until no more came out, sprayed some stuff in the holes and sealed them up. I found riding up a really steep hill, stopping and holding the bike upright seemed to get most of it out. Nice pics, rusty isn't it.
  9. Spicy Guacamole Husqvarna
    Midway Point, Tasmania
    TR 650 Strada
    Have people with this problem been riding through waterholes/creeks or just on wet roads? It must be a warranty claim regardless…..
    I’m hopefully picking up my strada this weekend, I'll have a look if swing arm has the new drain holes.
  10. spiderman Husqvarna
    Decatur, IL
    07 KLR650 07 Bandit1250 85 Rokon
    I'm thinking of drilling some holes, tapping threads, and inserting bolts that can be removed for draining once in a while. I would think that riding for a coupe of days in hot dry conditions should pretty well dry it out inside. Thoughts?
    Also. I'm concerned about exactly where to drill. I would want these holes toward the end to get as low as possible of course, but I'm thinking the rear of the swing arm may be solid rather than hollow to support the chain adjustment mechanism. Don't know how far from the end I should drill.
  11. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    Anybody thought about just blowing the water out with an air compressor? Drill the hole on bottom, and then push some air through using the holes for the mud flap where the water is entering. It should blow everything out. Repeat a few times and it should get good and dry in there pretty quickly.
    HuskyDude and spiderman like this.
  12. krider59 Husqvarna
    eastern pa
    trt 650 terra
    02 k12rs 05k12lt
    thanks for the heads up folks, I just took my terra through a knee deep stream crossing:(
  13. William42 Husqvarna
    Champaign, IL
    TR650
    XT1200Z
    That is what I am doing. I then spray a bunch of WD 40 into the swing arm.
  14. Spicy Guacamole Husqvarna
    TR 650 Strada
    Hi all, just some info for aussie owners (may be the same elsewhere) the water in swingarm problem seems to be a warranty fix now. I have had my dealer drill holes in the base of my swingarm. Apon collecting my bike the dealer said apparently the importer is drilling holes in the swingarms on new bikes as they arrive. Good news at last.....
    PaulC likes this.
  15. TerraCzar Husqvarna
    Ramona, CA
    2013 TR650 Terra
    Cool, can you show or tell us where on the swingarm they are drilling specifically?
  16. bluegopher Husqvarna
    Woodland Park, CO
    2013 TR650 Terra
    +1
  17. Spicy Guacamole Husqvarna
    TR 650 Strada
    This is where my dealer did it (3mm hole). I would of liked to of seen it axle adjusting plate? as in pics above. IMAG0428.jpg Still need to give it a good sprayout with rust preventer.
    TerraCzar, nev.. and PaulC like this.
  18. Toyboy Husqvarna
    Middletown, PA
    2011 TXC250/2012 TXC310, 2013 TR650
    BMW Hp2E/Yamaha Super T/BMW R1200RTP
    Jest a heads up on the rust thing. Had to change my rear brake line on my Terra. Went to unscrew the brake line hold down (8mm) that sits on the top of the swingarm and the screw came out but was already corroded where it sticks thru the swingarm. Leave one un-touched for a year or two and I bet it will shear off on you. I greased it before install. Might want to look at it.
    PaulC likes this.
  19. Ignaciob Husqvarna
    Tri-Cities, WA
    TR650 Strada --> Terra (aka Noxeema)
    05 Yamaha FJR (x2), 75 Honda CB400F
    Ever wonder how much water is in that swingarm? I drilled one side and was surprised. So much that I recorded drilling the other side. Notwithstanding my goof of breaking off the drill bit you can see flow lasts for quite a while. Fast forward to 0:59 to see the real flow start.
    Off to tap and seal things up on the problem end.
    Toyboy, TE250Guy, HARDER1 and 2 others like this.
  20. megatiker75 Husqvarna
    Italia (Liguria)
    TR 650 Terra
    Kawasaki ZX6R 2001
    ...oooo My God :eek:
