Water in swingarm
Discussion in 'TR650' started by Navelgazer, Apr 27, 2013.
  1. nwrider1 Husqvarna
    SW Washington
    Too many to list
    A falp is what happens when using the keyboard on a tablet with fat fingers:)
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Haha yes I have had mamy falps in my tine!
  3. danketchpel Husqvarna
    Camarillo, CA
    Terra 650
    Moto Guzzi, Ducati, Beta
    No, it's not the reservoir as I have other bikes with a similar setup that don't.
    I believe it's a material issue for some component in the system, probably a seal or aluminum surface that oxidizes. My Ducati Sport Classic clutch reservoir does exactly the same thing, but not the front brake which has the same type of reservoir located in nearly the same position and it's well noted among other Sport Classic owners, as is the rear brake on the Huskys.
    I have decided it's not worth worrying about.
    Mark_H and engineerk9 like this.
  4. Mark_H Husqvarna
    Lapu Lapu Cebu Philippines
    Like he said !!
    engineerk9 likes this.
  5. Snow Dog Aus Husqvarna
    Albury
    terra 650
    Terra 650
    What I found in my swing arm today
  6. andy839 Husqvarna
    75 Honda CB360
  7. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Do u plug the swingarm drain? If so then leave it open
  8. andy839 Husqvarna
    75 Honda CB360
    Shawbagga, see my long write up about how to truly fix this problem. It's at the bottom of page five of this thread (username Andy839). It's a permanent solution and also deals effectively with the rust already inside the swingarm.
  9. AlexK Husqvarna
    Greece
    tr 650 strada
    Yamaha mt03 2007
    Thank you my friend...after i saw your video i did the same.
    View: https://www.youtube.com/watch?v=M3oDIgodpME
  10. Mark_H Husqvarna
    Finally got round to the Flap Fix.
    I originally tried to seal up the 2 plastic rivets in the swingarm which worked but eventually the rubber flap itself broke in half.
    Now I have taken it apart and properly sealed the 2 swingarm rivets, basically using them to block the holes.
    Then I found some rubber sheet to replace the existing flap, but all I had was a little thinner and I thought it may not last too well.
    So I used half of the old Flap and added a piece of the thinner sheet behind it. The new flap just hangs down and the old piece keeps it straight.
    This way the water spray from the wheel does not get any where near the swingarm rivets and the shock is protected.
    Sealed up rivets in place
    New rubber behind the remaining piece of old flap.
    It just hangs down so the water runs straight off it.
    duibhceK likes this.
  11. franc Husqvarna
    Florence (Italy)
    TR 650 strada
    I bought my Strada to service (not Husqvarna dealer) just for having my swingharm holed, the mechanic, that I know for long, told me I was crazy,, but he did drill it anyway. I was expecting the usual water drip, but instead, not a drop of water spilled..
  12. Richard Colahan Husqvarna
    Upper Black Eddy PA
    71 250 Cross, 74 125WR, 75 250WR
    Vintage British bikes, 1969 Penton
    Just did a friends Terra this week...sure glad the chain adjuster bolts were not seized in place... 008.JPG
  13. DenGen Husqvarna
    Calgary
    TR650
    1974 DT250
    Looks like you drilled just in front of the axle slot, correct? That a good move. I'll be copying that.
  14. CarstenB Husqvarna
    NL
    F650GS Dakar
    this was only an issue on early models. Later ones had the drain holes at the bottom of the plate which holds the chain tensioner from the factory.
    franc likes this.
  15. MookieWilson Husqvarna
    nyc
    strada
    sxv,cb
    When I drilled mine years ago, around 4oz of water came out from either side. If you're getting little to no wet weather riding in there won't be any water.
    franc likes this.
  16. Richard Colahan Husqvarna
    Upper Black Eddy PA
    The water came out when the chain adjuster bolts were removed. I then drilled the holes...note Snow Dogs (up-side down) photo above for approx location. Then wire brush those chain adj bolts and put a heavy coating of Anti-Seize on them.
