What engine oil are you using?
Discussion in 'TR650' started by Coffee, Mar 4, 2013.
  1. James Rideout Husqvarna
    Nova Scotia, Canada
    Rm250, DR650
    I actually found the recommended oil for the TR. Holy crap. Castrol 10W-50
    Walmart Canada has it, not sure in the states though. Not cheap at $16 bucks a bottle.
    Ive got in arguments with bike shops and auto parts stores that 10W-50 actually exists. Most places just tell me it dosent exist and it must be a typo in the manual.
    I hate dealing with the guys across the counter. If its not on their computer screen, than it must not exist and your dumb.
    I f%*Ked up last night doing my oil change. Manual says 2L exactly will top it up. So I bought 2 bottles not realizing that a bottle is just a tad over 900ml (brain fart). Enough oil to just touch the tip of the dip stick. So looks like ill be packing my ass aboard the Mitsubushi and going to Walmart.
    So is pajama pants, crocks and a AC/DC jean jacket considered over dressed for Walmart?
    Thehowell71, mag00 and huskybear like this.
  2. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    Overdressed, probably. Swap the jean jacket for a wife-beater and you'll fit right in.
    mag00 and Tinken like this.
  3. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Depends on the wal mart
  4. Coffee CH Owner
  5. MadDogTR Husqvarna
    Bakersfield, CA
    Yes, many.
    Castrol 06412 Power RS Racing 10W-50 4-Stroke Motorcycle Oil is what I use. If you contact Castrol they will tell you that it is a completely different blend of oil and they wouldn't recommend using one for the other. But if you compare the descriptions of the oils on castrols website, they compare word for word. Castrol says some KTM shops in the U.S. carry the oil. The KTM/BMW/Yamaha/Victory shop near house does not.
    I call B.S. on Castrol.
  6. Coffee CH Owner
    I've lost track of what Mobil 1 you recommended in March 2013, any specifics? Part numbers?
  7. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    There's no way I can remember back to March, haha.
    But, I wanted to share with you that I did some recent research into the BMW GS650 engine since I was curious about which oil to have my customers use. BMW originally specified BMW brand 15W50 oil be used in this engine. Anyone familiar with BMW brand oil knows that for the last 15 years, this oil is actually re-branded Golden Spectro and should probably never be used. After speaking with several BMW mechanics, I am told that they switched their race bikes all over to a grade 40 oil, more specifically, M1 4t 10W40 gaining excellent results in shifting, power, and even idling. I see no reason why M1 0W40 or Rotella T6 5W40 couldn’t be used in the GS650 engine unless you do not plan on changing your oil prior to 1500 miles.
  8. dangslow Husqvarna
    St. George, UT
    TR650 Terra and a TE310
    100_1855.jpg I use Torco T-4R. It was recommended by the guys at Bills. And it comes in 1 Liter bottles. Makes a 2 Liter oil change pretty simple.
  9. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    Ive also had good luck with this, but switched my 449/511 to the 0W-40 Mobil 1 since that engine benefits from good early oil sprayer flow. Used the Torco for several years and never had a problem with it.
  10. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    I would have taken it for a ride to get the oil to operating temp. I reckon it would have been spot on when you rechecked it...
  11. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    I use Mobil 1 4T 15w-50 part # 98X514 which is in a 4 litre container.
  12. FER QUILES Husqvarna
    SPAIN
    TR650
    KLE500, HONDA NX650
    I used motorex 10w60, but a bit expensive..
    summertime here in alicante spain is very hot, 35-39 degrees, and to do gravel, below 25km/h do not cool enaught..
    • [IMG]
  13. Coffee CH Owner
    The oil change interval for the TR650's is 6,000 miles.
    Any chance you could provide a link to this site to the specific product?
    http://www.mobiloil.com/USA-English/MotorOil/Oils/Oils.aspx
    Cannot seem to find what you are referring to.
  14. chris1261 Husqvarna
    North Jersey
    2013 TR 650 Strada
    2013-06-05 11.51.23.jpg Found this at pep-boys.
  15. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    I use Amsoil Formula 4-Stroke 0W40 in my 310.
  16. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    '12 250XC '09 1200GSA KLR650
    I know this is a TR650 forum area and I was just reading for research. In the 250 x-lites I'm running Lucas full synthetic 10w40. Both bikes are still on original motor, no rebuilds with lots of hours. So...But I am always interested in improving things.
    I was looking for on-line comparisons and here's one from 2006, all I can say is there is a science to this; are there any more current comparisions out there? And if I follow along with the Lucas products in this comparison...I may be looking to switch.
    And, if the current Amsoil products are still up to performance level of 2006; winner. But then again they performed (or paid) for the test.
    Read into it what you want and form you opinion; later...
    http://www.combscustoms.com/pdfs/Amsoil_Study.pdf
    Found a 2nd edition test of the above from 2009, kind of the same results.
    http://wpc.1c96.edgecastcdn.net/001C96/G-Items/Performance Testing Archives/g2156-2009-archived/index.html
  17. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    The Castrol is what I currently use in my 310. 5 bottles left of my case and will likely follow suit to Mobil 1 0W-40. But... Quart bottles of the stuff are sold out at Wal-Mart because of Tinken ;-) (gals. available though for cheap)
  18. MadDogTR Husqvarna
    Bakersfield, CA
    Yes, many.
    I wouldn't use the Mobil 1 designed for cars. It is not formulated to go through transmission gears or wet clutches. And the specs surely won't be right for our TR650's. That would be an instant warranty denial.
    Ignaciob and rajobigguy like this.
  19. Nordic Husqvarna
    Missouri
    2012 TE310
    Oset 20
    Mobil 1 0w40 in my 4 stroke
  20. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    This is exactly what motorcycle specific oil manufactures want you to think. This way they can sell you their specific oil at a premium price. The truth is that not only do some of the auto specific oils work perfectly with motorcycle engines and wet clutches, in many cases, they actually out perform motorcycle specific oils.
    dave lindsey, blakebird and Nordic like this.
