What Oil Are You Using?
Discussion in '610/630' started by boxofish, Aug 22, 2011.
  1. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    Yep. I warm mine up every time I start it. Unless I just shut it off a minute ago, that is.
  2. RDTCU Husqvarna
    '11 630SMS
    Yeah, but don't let the bike sit there idling for more than a minute or two, the twin cam heads run hot at idle... I warm mine up for about a minute in the mornings then ride it easy for the first few miles.
  3. ContraHusky Husqvarna
    BTW -- I just got back from WalMart. Rotella T6 for $21.36 a gallon. :applause:
    and...it is JASO-MA certified. Right there on the bottle. Suitable for common sump applications (motor, trans, clutch...).
    jtemple likes this.
  4. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    Yep, love the stuff.
  5. BadMotoWeazal Husqvarna
    Alabama
    rekluse actually specs Rotella for its auto-clutch....
  6. Husky Doug Husqvarna
    Mt. Juliet TN
    Amsoil 20w50 for me...I've had such good results using Amsoil over the years, I became a dealer. :thumbsup:
  7. Rattletrap Husqvarna
    Alabama
    Wal-mart Supertech 20w-50 in the summer, 10w 50 in the winter, what ever is cheapest and change it every 500 miles or so.
  8. Blazes Husqvarna
    South Africa
    Eddie Seel 634SMR works Replica -
    Aprilla Dosodoro 2X 2009 610
    Rotella on all my bikes --:thumbsup:
  9. pinocono Husqvarna
    I just did my first oil and filter change at 200 miles. I used Motul 5100 15w50, but may switch to the Rotella T6 that many others are using.
    The oil looked fine, but there was a lot of little sand grain sized metal pieces caught in the screens. The magnetic plug was covered with a bit of metallic sludge. I'll change the oil and filter again at 1000 miles, hopefully I won't see as much garbage.
    BadMotoWeazal likes this.
  10. BadMotoWeazal Husqvarna
    Alabama
    Very typical in all makes of new bikes as the gears mesh & metal flies!!!
  11. Circus Husqvarna
    San Diego
    Shell Rotella T 15W40. Shifts smoother and for the entire period between oil changes. As was said earlier, $13 a gallon at Walmart.
  12. pinocono Husqvarna
    I haven't seen this much debris in the other 5 new bikes I've bought in the last 10 years. Granted, none of them had the steel screens to trap the larger bits, they could have been in the oil filter. All had magnetic drain plugs, and were much cleaner than the 630's. I'm not going to worry about it, I didn't see anything that looked like something was disintegrating, just looked like machined parts weren't cleaned and/or deburred very well in manufacturing.
  13. BadMotoWeazal Husqvarna
    Alabama
    Probably so, keep us posted....
  14. sms 630_newbie Husqvarna
    We Pulled and cleaned screens and changed oil and filter with 10-W-50 Full Synthetic Castrol RS 4T Racing oil.
    2011 SMS 630 Owners Book says Power 1 Castrol 10/50 .power 1 Must be Euro-oil .
    This is the Good Stuff . Costs you about $35.00 to load your Machine with 2 Bottles of this Full Synthetic Castrol And a new Filter. :cry:
  15. sms 630_newbie Husqvarna
    THIS IS WHAT I USED. 10W50
  16. blakebird Husqvarna
    Parker, CO
    '16 FE501S
    '14 Super Tenere
    Silkolene 15w-50 Pro 4 SX
    I went in for Motorex 10w-60 Cross Power (I use Motorex 10w-60 Power Synt in my Guzzi) and they only had one bottle....and I've used Silkolene many times and like it.
    Have tried every other oil mentioned except Rotella, and have no doubt they would all be good choices.
  17. shoolsema Husqvarna
    Vancouver, Canada
    summer rottella T 15w-40 dino
    This winter Rottella T 5w-40 synthetic
  18. deepcdiver Husqvarna
    earth
    Cycle Gear just put the Castrol RS 4t 10-50 full synthetic oil on sale for $9.95.
  19. ghte Husqvarna
    Bright, Victoria Australia
    Most oils work well. The trick to slick changing and engine longevity is regular oil changes. Particularly bikes wher the clutch and engine oil are one and the same. I change my Dirt bike oil after every 3 rides and the filter every second oil change.
    On my road bike (ducati multistrada) I change it every 6000 kms which is half manufacturers recommendation ie twice as often.
