125-200cc Will crimped pipe hurt performance
Discussion in '2 Stroke' started by Pedec, Feb 3, 2016.
  1. Palito Husqvarna
    Ontario, Canada
    2009 WR300, 1986 430AE Auto
    1989 DR600
    I had a friend straighten a pipe with water pressure, capped one end and filled it with water making sure no air is trapped in it. Capped the other end and attached a high pressure hose to a laboratory test hand pump. Critical thing is bleeding out any air. Then simply pumping it up slowly and watching as the pipe straightens out before your eyes. It takes as much as 800-1,000 psi but is safer than heating an air pressurized pipe. Water is not compressible so if it develops a leak or splits a seem open the pressure is released immediately, no projectiles or catastrophic damage to the pipe. Absolutely critical not to have air in the system. This works best to restore the shape of a pipe and large caved in dents, not so good on the little stone dents. The pump my friend used was about 60 years old, don't know if they still make them. Also it only took about 3 or 4 pumps on the hand lever to achieve those pressures. If it takes more the a few pumps it means there is air in the system that needs to be bled out. I was totally amazed by the process.
    wallybean and lankydoug like this.
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    jmetteer, duggoey, everfree and 2 others like this.
  3. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    That bloke is a loony!!
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Hes restrained compared to most us brits ;) well me any way
  5. everfree Husqvarna
    Bend, Oregon
    86 430AE (2), 88 430AE, 87 430WR (2)
    87 250 XC, 87 430 CR, '17 GG 300
    Do all Brits wear a tie when they work in the garage? :)
    duggoey likes this.
  6. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I think he's had too much...uhhh...tea :rolleyes:
  7. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    That guy Colin is a the perfect example of the fine line between genius and insanity. I love his stuff!:cheers:
    jmetteer likes this.
  8. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Yeah but pants are generally optional.
    everfree likes this.
  9. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    I knew a painter decorator that worked in a 3 pice suit.
    It was pristine an wore no overalls.
    You can wear what you like cant you?
  10. SmokeyExpress Husqvarna
    Canberra Australia
    2014 WR300, 1996 WR360,2013 WR125
    That bloke is the same guy who made a pulse jet & fitted it to an old bicycle if I'm not mistaken! Clever fella but a bit happy go lucky! Search for the Pulsejet video! owmygewd if you think he's a looney in this vid you ain't seen nothing yet!
  11. SmokeyExpress Husqvarna
    Canberra Australia
  12. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yup hes colin furze, built a bunker for the apocalypse sponcered by sky!
    Drift trike, heated slippers, vacume dlippers, magnetic shoes, wolverine claws, flame thrower hands and working assasins creed blade n grappling hook. Thats a few of the fun things he do lol
    Record holder for fastest mobility scooter and made a 600cc tuk tuk
