250-500cc WR 250 built thread
Discussion in '2 Stroke' started by Miezie666, Jul 29, 2015.
  1. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Think the clearance issue was the air boot/ reed block rubbers set up for a longer carb.
    Oh and giggles my itallian domino lever never killed a cable but the American Msr raptor did...
    Crappy products ;)
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    something might have changed with the age of bike but the stock setup rubbed badly. have heard this complaint on both 250/360.
    would be shocked if anything msr was still made in the states, sadly...likely chinese..
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    True but was sent from the states and has their name assosiated with it, their design sent to china for manufacture so imo its American.
    An its probably my fault for installing it wrong or something. Lol
  4. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    I did had some trouble kick starting my bike- weak spark... Thats why i messed around with the carbs in the First place.
    But i remembered your post and i thought i ll give it a try... I found out the flywheel is not the right one...
    So i swapped the existing flywheel for another one- baam! Starts First kick with ease using sneakers.
    Willy from HPI told me not to use resistor spark plugs and a non resistor cap.
    454x, juicypips and johnnyboy like this.
  5. Claybilly17 Husqvarna
    Ohio
    2000 WR250
    2009 KTM 450 SXF
    Is that bolt supposed to be there above the fly wheel? I thought it was supposed to be a vent line??
  6. Miezie666 Husqvarna
    Germany
    It looks like oem- there is a guide/clamp for the wiring underneath.
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yes its got a clamp underneath to hold the wiring out of the way.
  8. Miezie666 Husqvarna
    Germany
    Nearly... :-) IMG_20160217_213906.jpg
    454x likes this.
  9. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Omg your not keeping that seat colour are you, ARE YOU!
  10. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    :lol:
  11. Miezie666 Husqvarna
    Germany
    I bought a new seat cover- but a friend has got a black seat already for his blue/yellow husky- we ll do a swop when we meet next time.
    I did a short test ride yesterday and i found out a Big problem: the engine has so much power - i ll get a flywheel weight made for that. Thats an MX engine right now! HPI is for what it name says really! Compared to a stock WR250 this one is so much more agressive- i will get in trouble with that.
    454x and juicypips like this.
  12. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thats the way to go for my 360 then, you wouldnt be interested in original wr ignition set up with money your way for hpi would you ???
  13. Miezie666 Husqvarna
    Germany
    I ll keep my ignition. Its new, its got the dual map, its just a set up thing to make the bike perfect
  14. Miezie666 Husqvarna
    Germany
    I was doing a First test ride today- about an hour or so, its been raining 5 days now- so everything was wet, very deep ground- Best weather for a proper test! First of all - i love this suspension- its been great, traction was good, even not beeing setup right. Will do some more work on the suspension to make it really perfect. The engine had enough power, still on break in but great torque and a very long 5th gear like an overdrive.
    Cosmokenney, juicypips and NCSteve like this.
  15. Miezie666 Husqvarna
    Germany
    I got the black seat cover today...
    wrx, JAM and juicypips like this.
  16. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
  17. Miezie666 Husqvarna
    Germany
    ticked another box on my list today...
    NCSteve, shawbagga and juicypips like this.
  18. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Lookin good mate are those forks all gold?!!
    Hit up 7602 racing for a case saver n clutch cover with oil sight glass(if any left!). Makes checkin oil so simple. Maybe rad guards too?
    Are you goin to run a bash plate?
    I like the older style bodywork
  19. Miezie666 Husqvarna
    Germany
    Yes- upper and lower fork is gold, its an aftermarket Öhlins i borrowed from a Yamaha WR250F 2001/02, i m also using the front wheel hub and brake system- but i need to upgrade this.
    I will build my very own bash plate- but at the moment i dont have my wig welder ready and i m ill...
  20. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Whaaat i got 03 wr250f yammy an its not got ohlins!?!
    Wtf this is an outrage gunna start smashing things........................
    So i need to get in on this action.
    May hook 360 up and get it super sweet ready for her 16th ;)
