250-500cc WR 300 rattle noise
Discussion in '2 Stroke' started by hogwackr, May 14, 2011.
  1. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Good deal.
  2. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Honda CR250 reed block gaskets fit perfect in there. I bought 2 of them for about $5 and sealed both sides of the reed cage with them.
  3. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    Good to know.....I used rtv. [IMG]
  4. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Husky needs to wise up on this one and start using a gasket here.
  5. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    I agree. I had to learn the hard way.......[IMG]
  6. russell timmins Husqvarna
    2011 wr 300
    2006 yz450f
    I just noticed my bike doing this exact same thing. I had the casing off last weekend to fix the dreaded gear changing issue. Rode it last night fine and today it starts making the noise that your describing.
    Just re-pulled the clutch out to make sure everything is ok. Test ride and theres the noise.
    Did sealing up the the reeds fix the problem? Pretty concerning as Ive had the bike for 3 weeks and had too fix twice already.
  7. justpinit Husqvarna
    Maryland
    2012 wr 300
    93 kx 125 with a kdx 200 engine.
    There was a rattling noise on my 300 at the rpm range you specified. It turned out to be the exhaust springs. I slid them inside of a radiator hose, and it went away.
  8. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    Can someone please share link for a correct gasket? Or what year cr250 will work?
    Thanks!
  9. shrubitup Husqvarna
    Seattle WA
    92-01 Honda cr250 reed block gaskets are a perfect fit. Same exact bolt pattern and size. I owned a 98 99 and 01 models.
    ks9mm likes this.
  10. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    Thanks
    Thanks!!
    I just took close look at mine and I see gasket between reeds and cylinder. Do I also need one between intake boot and reeds?
  11. shrubitup Husqvarna
    Seattle WA
    Yes, this is the common air leak area.
  12. broken biker Husqvarna
    1994 TE 610 2012 WR 300
    your dealer may know something u have not even considered.the ducati ignition can be faulty that causes poor,inconsistent spark-difficult starting-fierce kick back-engine seizures[in my case 3 that were fixed under warranty,not related to jetting,mixture,air leaks,dusted engine]
