250-500cc WR 300 running hot-really hot
Discussion in '2 Stroke' started by Guy Lozito, Aug 11, 2013.
  1. Glenn haynes Husqvarna
    western pa
    2012 wr300
    13 yz250f 08yz85 11ktm 65 09 ktm65
  2. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
  3. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    Glad that was a simple fix. since that seemed to be the culprit, you may want to consider making a papergasket for the seal there. When you take off the reed cage, you will see the numbers are stamped right on the sealing surface of the block. That is the culprit. Now we need to get you to stop touching your cylinder after you are done riding.:lol:
  4. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Honda paper gaskets will fit the Husky reed cage and are not expensive. Bills put paper gaskets on my 09 WR250 before they shipped it new in the crate
  5. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    @ Guy - One of the issues I see happening is with coolant. EngineIce uses water to thin their poly mixture and after that boils off, the poly gets as thick as 140W gear oil. Many of the guys on here remove any restrictions, such as thermostats and switch to XF coolant which will never thicken.
