WR 400 -86
Discussion in 'Vintage Restoration Projects' started by P-A Calmhede, Mar 21, 2017.
  1. Alistair Frisby Husqvarna
    Ontario, Canada
    1986 WR400 LC
    Triumph 750 Trident
    Hi guys, would anyone have a downloaded workshop manual that shows how the electrics connect to the frame/engine/handle bars? I did download one manual from a vintage husky site (UK based i thought) and its in swedish but doesn't really show any electronics (only mechanics). If someone has a PDF or link to a really good detailed view, that would be great. I can supply my email if anyone wants to send it to me rather than post it. Thanks all !
  2. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    that's a great job done there allright. sweet looking scooter:cheers:
  3. P-A Calmhede Husqvarna
    Sweden
    TR650 ,FE350,Silverpil,Svartqvarna
  4. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Awesome looking bike! Apart from normal tank yellowing, I prefer the look of the '86 over the later models.
    How did you get your tank so white?
    Tony.
  5. P-A Calmhede Husqvarna
    Sweden
    I haven't done anything more than just normal cleaning. It looked very good from the beginning. Used steel wool together with foam to pollish certain parts. It worked very well
    ajcmbrown likes this.
  6. Alistair Frisby Husqvarna
    Ontario, Canada
    1986 WR400 LC
    Triumph 750 Trident
    Hi there, really nice job. Can i ask a big favour…do you have any close up pictures of how you attached the electronics to the bike that you can post. Also one of the chain tensioner set up? Thanks a ton!
  7. P-A Calmhede Husqvarna
    Sweden
    Hi Alistair! Thanks. Of course will I do that. Is it the electronics under the tank you are interested in? Will take pictures later. No problems!
  8. Michel Dufayard Husqvarna
    France
    Basically, must be the same from 80 to 88.
    Alistair Frisby likes this.
  9. P-A Calmhede Husqvarna
    Sweden
    Yes it is the same on my -81 and my -86.
  10. Alistair Frisby Husqvarna
    Ontario, Canada
    1986 WR400 LC
    Triumph 750 Trident
    That would be wonderful … i hope its not a big hassle to remove tank for that? Much appreciated.
  11. Alistair Frisby Husqvarna
    Ontario, Canada
    1986 WR400 LC
    Triumph 750 Trident
    Awesome diagram. Thank you so much.
  12. P-A Calmhede Husqvarna
    Sweden
    I will take pictures this weekend.
  13. P-A Calmhede Husqvarna
    Sweden
    Hi Alistair! Here are som close up pictures of how the electronics are attached to the bike. Also pictures of the chain tensioner set up. If you need more pictures just let me know.
  14. Alistair Frisby Husqvarna
    Ontario, Canada
    1986 WR400 LC
    Triumph 750 Trident
    Fantastic photos and very helpful. I am grateful for these - Thank you!
  15. Alistair Frisby Husqvarna
    Ontario, Canada
    1986 WR400 LC
    Triumph 750 Trident
    P-A hi, did you feed the wiring harness up through the main frame down tube (the one which has a hole just under the headstock) or just attach it to the down tube? Just trying to work out how to best route the harness around the radiators etc. Cheers, A
  16. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    should be zip tied to the back of the front down tube im thinking
  17. P-A Calmhede Husqvarna
    Sweden
    Alistair! As Suprize said it should be zip tied to the front down tube. I shall see if I can upload a picture later.
  18. P-A Calmhede Husqvarna
    Sweden
    Hi! Now the restoration work will start again with the WR400. First of all I will paint the exhaust pipe and make the silences look nicer. I will also paint the Öhlins shock absorber. The radiators will be looked after and all the hoses replaced. When I checked the water pump housing I noticed that the transmission cover had oxidied and that water had mixed with the oil. Not good. I don't know how to solve it? New transmission cover? If someone have an idea it would be nice. I will upload pictures soon.
  19. P-A Calmhede Husqvarna
    Sweden
  20. P-A Calmhede Husqvarna
    Sweden
    Corroded water house pump
    wrx likes this.
