250-500cc WR250 power valve adjustment?
Discussion in '2 Stroke' started by Bench Racer 117, Aug 14, 2010.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I did mine @ the 50.5 last year. I bought one of those machinist rulers with the slide @ one of the Home improvement stores. It was either set wrong at the factory or slipped. What a difference it made along with crisp jetting.
  2. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    Is it worth doing? What kind of difference did it make? Low end? Better all around power?
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    It gave me a crisper bottom end up thru the mid. I wish I would of checked it when it was new.
  4. lankydoug Husqvarna
    MO
    WR
    TM 300en
    for some reason I can't view any of the images that you posted.:excuseme:
  5. 2stroked Husqvarna
    B.C. Canada
    I still have the TMX, with a JD kit and a 4.0 slide, Gnarly pipe and I have ridden a friends with the PWK and there wasn't much difference but they are a little finicky for sure.
  6. raisrx251 Husqvarna
    Virginia
    I am having trouble finding the pictures as well on my computer. I will look on a backup hard drive and see if I have them. Really all it showed was the plastic ruler setting in the cylinder measuring to the top.
  7. Steve-oh Husqvarna
    Lethbridge, Alberta
    2010 WR 300
    04RM250, 05XR100,07PW80,41 Harley
    No images as well ???
  8. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    Great posts but the pictures aren't showing
  9. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    What's a 4.0 slide?
  10. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    haha...it's the part of the carb that slides up and down :thinking:
  11. Jhunter Husqvarna
    Atlanta
    Here's my 2 cents... Find some 90 octane gas without Ethanol (corn). Second, purchase a JD Jet kit for $75. That combo will work wonders on your motor. Cheap easy fix and can be done in less than an hour :popcorn:
  12. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Maybe it's been posted elsewhere, but I was told you can buy non-ethanol gas at any marina. I haven't checked, but soon will.
  13. lankydoug Husqvarna
    MO
    WR
    TM 300en
  14. shrubitup Husqvarna
    Seattle WA
  15. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    13 Pure Gas Stations in California, every single one is in Southern California
  16. lankydoug Husqvarna
    MO
    WR
    TM 300en
    The app is updated by users so there could be places to buy fuel that are not on the app. If you know of some you can add them to the app and future users will benefit.
  17. Hammerz Husqvarna
    No one has mentioned fitting divider plates in the TMX, I did this to my 300 and got a bit improvement in low end power. Bike pulls like a four stroke now, although I think the rekluse I installed at the same time helps spread the power also.
  18. Errk Husqvarna
    2004 wr250
    Another thing to make sure everyone dose is adding a 1.3 mm spacer to preload the power valve spring. Just make sure the spacers ID is the same as the shaft so it has no movement ( this system needs to remain balanced) this mod greatly improves mid range and completely eliminates bog before the powerband. It makes the power very linear and there is no hard hit just a smooth pull. Top end remains the same which for me is enough to make it hard to keep the front wheel down in every gear. The reason the 250s bog just before the power band is that the power valve is opening to early. The spring preload shim makes the power valve open a little later getting all the mid range back. I did this to my 2004 wr250 btw and wish I did it a long time ago. Yes you have to remove the case cover and drain your fluids but it is well worth it in my opinion
    Cosmokenney and NCSteve like this.
  19. mr_manny Husqvarna
    Jalisco, Mexico
    wr250
    Is anyone familiar with this mod?
    Currently have my power valve/jug apart, and would appreciate any additional information on this mod.
    Cheers
