250-500cc WR360 Motor and Gearbox in a 2011 WR300?
Discussion in '2 Stroke' started by icebergstu, May 2, 2012.
  1. broken biker Husqvarna
    1994 TE 610 2012 WR 300
    bought a new WR300 from Trooper Lu,s Garage.had 3 warranty repairs of top end,seizures,barrel cracked between exhaust&sub port.stator replaced under warranty.they screwed me around,wasted time,bike sat in workshop 4 two weeks due to a computer fault,parts took weeks to appear,storys were told then changed or denied,service manager on long service,then is sacked or leaves,emails ignored or blocked.contacted BMW [parent company],which got PFG responding 2 emails,then more BS.fair trade might do something if they get bombarded with compliants
  2. coca2113 Husqvarna
    Blanding UT
    2000 wr 360
    If you do the swap with the 360 I would be curious to know how you like it. I have a lot of mods into my 360 engine but the rest of the bike isn't as nice. So a modern frame is begging to have my 360 in it. Let me know how it goes.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    a 360 and 300 share cases so its a bolt in
    the pipe will be the only issue, you might need a custom built
    please post pics of the swap
  4. justpinit Husqvarna
    Maryland
    2012 wr 300
    93 kx 125 with a kdx 200 engine.
    Any chance i could by the trans gears out of the 300, the engagement dogs on mine are destroyed.
  5. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I sent you a PM.
  6. 2premo Husqvarna
    Northern NV
    the biggest advantage to the 360 gear box is 6th gear, as in another gear
  7. Xriderdown Husqvarna
    La Center, Washington
    WR360 SW / WR360 IT / FE501 AU
    BUL MK3,KAW KE100,CZ 988-1,YAM FZ1
    I recently updated the body work on my 2000 WR360 to 2007 plastic. I was in the hunt to replace the stock ESP pipe. I was told a WR250 pipe would work so I purchased one. It did not work in this situation. The exhaust angel coming out of the head was way different. So I nickel plated it and stuck with it. I'm going to assume you will have to use your stock 360 pipe. This will probably be a good thing since you mentioned you like the low end power band anyways. The frames and the engine mounts of both the 360 & 250 look identical but, as in my case you may run into an exhaust alignment issue.
    Good luck!
    Rob09, 2premo, mkfox and 1 other person like this.
  8. Travis Thompson Husqvarna
    1991 wxe 260
    1978 yamaha xs750 special
    ^that is sweet!!
  9. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    I concur.
  10. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    It looks like I will be doing this swap soon as well. Trashed my 300 a few weeks ago, and I don't trust that the ignition system isn't to blame. So, I'm a bit hesitant on the rebuild. Meanwhile, I found a recently rebuilt WR360 (complete bike) for a great price. So, I plan to pick that up Saturday, then swap the engine over to the 2012 WR300 frame. So, I can finish out the season. That should buy me until March/April to get all new ignition and rebuild the 300 to my satisfaction and drop it back in.
    I figure I'll go ahead and put my Lectron 38mm on the 360. The pipe situation might get interesting. I've got a local guy that does great work blowing out smashed pipes, but in the last 15 months I've acquired 2 stock WR300 pipes, 1 DEP pipe, and 1 Pro Circuit pipe. So, I might see what I can't do to fit one of the stock 300 pipes. A bit of heat, and bending, and maybe welding...but it'd be nice to have a spare with the way I tend to smash them.
    icebergstu likes this.
  11. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Please do a separate detailed build thread for us all to enjoy with heaps of pictures and info!
    Stu
  12. 2premo Husqvarna
    Northern NV
    my guess is the port for the pipe might be the actual issue
    the 250 and 300 are base off the same basic engine just oversized bore
    the 360 stands alone from these, while the different years list different pipes it might be the mounts that changed due to frame geometry
    the point made about the pipe being used on a different cc engine had the pipe at a bad angle, sound like the exhaust ports are different
    they don't share power valve parts, just saying
