Wrong part wasted money
Discussion in 'Vintage Restoration Projects' started by Caden, Aug 24, 2016.
  1. Caden Husqvarna
    1983 husquavarna 125xc
    1983 Honda cx650c
    Maybe the bike is older than I thought too.
  2. disonny Husqvarna
    upstate ny
    73 360 wr/rt, 75 wr250 78 cr250,
    83 wr250, 84 wr400
    Frame number should be on the steering head, right side. vintagehusky.com has a ID chart
  3. Caden Husqvarna
    1983 Honda cx650c
    I looked there. I didn't see it. I thought I saw a number somewhere in there. I'll look when I get home. Thanks
  4. Joe Chod Husqvarna
    upstate NY
    right side of steering head. The tube the steering stem goes through
    looks like an 83 should start with X0 or W0 then more numbers
    where are you located?
  5. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Joe, is right, it's a 125, after I looked at the newest (2nd) engine picture, you posted a lot closer, couldn't see the cylinder size that well, in the 1st one, besides the picture being upside down..lol
    Besides Joe knows 125 Huskys, like no one else I know....:notworthy:
    White frame so it's probably a 1983
  6. Bigbill Husqvarna
    '83 250wr
    0 right now
    The engine number is on the riveted plate over the sprocket.
  7. Joe Chod Husqvarna
    upstate NY
    no riveted plates on 83's stmped in cases near kicker on left center case. riveted tags are from before 83
  8. Bigbill Husqvarna
    '83 250wr
    0 right now
    That's the older style motor?
  9. Joe Chod Husqvarna
    upstate NY
    yes but an 83 motor.....side cover has been replaced from an older 250. 125 stayed with older cases and it did not even get primary kick til 84. the red headed stepchild of the Husky line.
  10. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    your motor and frame is a
    125 CR/XC/or WR 1983 !
    cranckase is before 1981
    (250/390 )
    and 125
    (1976/1982 )
    your carb is MIKUNI 38 mm
    look picture my motor !
    125 WR 1983
  11. Caden Husqvarna
    1983 Honda cx650c
    Thanks I figured out it was a 1976 cover
  12. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    Its a 1983 model. White frame with lay down rear shocks and top entry airbox. 84 125 was water cooled motor.
  13. Bigbill Husqvarna
    '83 250wr
    0 right now
    I guess the 125cc lagged behind the 250's design wise. I had three 125's two '85's and one '86.
