XC125 82 Restoration
Discussion in 'Vintage Restoration Projects' started by hoppy, Jul 25, 2014.
  1. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    you have in australia on eBay
    (sawtell -NSW-) 1 hva 125 XC
    for parts (motor ,.....)
  2. visiteur1948 Husqvarna
    france Europe
    husqvarna only
  3. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    125 husqvarna XC 1982
  4. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    kit conversion 125/175 husqvarna 1982 (only USA/AUSTRALIA ,no europe )
    oldbikedude likes this.
  5. hoppy Husqvarna
    Melbourne, Australia
    CR250 1982
    Husky 701 & TE250 17
    Another question I have the old wiring loom but no switches, what do people recommend using for light swithes and kill switch.
  6. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I just wired it all direct, no switch. there was a std husky square killbutton the 400, plugged it into the spot on the coil for it.
    would take nothing at all to grab a jap switch block and wire in hi low etc., use the horn as a killer
    justintendo likes this.
  7. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    have choice your ignition
    SEM or MOTOPLAT ?
  8. hoppy Husqvarna
    CR250 1982
    We have installed the SEM ignition in it, the frame has the correct mountings to suit it so will give it a go first.
    Have given it a kick and has spark will hopefully get it running over Christmas.
    Will install the motoplat if the sem gives me grief.
  9. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    (2 ) cable (s) yellow =ligths (70 w one ! )
    1 cable orange =stop engine !
    hoppy likes this.
  10. hoppy Husqvarna
    CR250 1982
    Have had the xc running not real good but a start.
    Also have just acquired some shocks to suit, got the 420mm ones to lower it a little for the bush.
    When I rebuild the forks is it possible to shorten them a little to lower the front a bit?
    Hopefully will have it ready for its first vinduro next month... :)
    Motosportz, vintagecs and dartyppyt like this.
  11. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    you can get some later wr damper rods which will reduce travel to 10"
    hoppy likes this.
  12. hoppy Husqvarna
    CR250 1982
    Hey all just trying to find out the type of fork oil and the quantity or level for fork oil in the XC?
    Cheers Rob
  13. euro bikes Husqvarna
    How are you going with the 125 ? I'm on the sunny coast QLD. Australia. I have a 77 which is ready to when I work out the timing on the motoplat. Fork oil is usually 6 inch's from the top with forks compressed , some people will bash me for this but I find 20/50 engine oil works fine .
    hoppy likes this.
  14. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    haha so does my dad . it works . sort of
  15. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    This is from the 81 tech ref in the vintage tech section. 1st value is for an oil change the 2nd is for a complete dissassembly
  16. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    sorry, it didn't copy...440cc XC/CR, 450cc XC/CR SAE 10 - 30 is recommended wt
    hoppy likes this.
  17. hoppy Husqvarna
    CR250 1982
    Thanks for the info guys, bike is slowly getting there lots of missing bits taking a while to get.
    I wouldn't buy a bike like this again, one that someone has had a go at and just basically made a mess of it.
    I have a KTM which needs lots of work also but at least it had just been sitting and is all complete and unmolested.
