Your opinion please for WR 400 1985 !!!
Discussion in 'Vintage/Left Kickers' started by petros67, Jan 12, 2013.
  1. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i was under the impression if it had the extra bolt hole by the kicker it was AL? ill tell you one thing, you can tell by their weight. i have a bunch of covers tho to compare.
  2. justintendo klotz super techniplate junkie
    looks al to me...likely wouldnt look like that if it were mag either.
  3. fran...k. Husqvarna
    eastern ct
    I can't tell from that section. The 87-88 has the bumper with that tiny allen type fastener through them. They also have a steel sleeve in the shifter and kicker hole and the clutch cavity is bigger. The aluminum is significantly heavier, I bought a four stroke case half not paying attention and it sure is noticeable the weight difference. I have no heavier clutch covers. I won't argue that such a thing has been produced I just think that it came on a new machine is unlikely due to what I have accumulated. I file off some shavings with a coarse file and then us an oxy propane or oxy acetylene tiny flame.
  4. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Thanks Fran, I will try it so that I know.
  5. ajcmbrown Husqvarna
    I should mention that the cover doesn't feel any lighter than any other cover, and yes it does have the bump rubber (split, I will replace) as you mentioned Fran. I don't suspect that this one is the original, I imagine that it was replaced at some time.
    Tony.
