08 TXC 510 stuck piston without warning
Lesson for me here.
I ride in the cold and I have a fairly steep up hill maybe 1/2 mile from my garage. I try to take it easy and downshift to keep the load off the motor but I'd better let it warm up a bit more next time.
Good news is I do run Mobil 1 0/40!
Wow. You have to assume all plain bearings are hosed for sure. I'm surprised this was the first symptom, usually you hear a hard knocking from the big end bearings failing first when you run out of oil. I suppose if there is an oil jet shooting the piston and it stopped somehow this is what would happen. Someone mentioned inspecting the oil pump, that's definitely a good idea.
I finally got the the 530 piston and and my cylinder back from Toxic. Now I just need to find some time to tear the bottom end apart.
ooooohhhhh shiney :applause:
does this bike have a thermostat at all ? maybe you should fit an extranal one . its as easy as cutting a hose and clamping it in
Are there oil sprayer nozzles by the crank that spry the bottom of the piston? KTM's have them. This would account for the melted piston if your oil was low.
