'13 TE449 Questions
Might as well chime in here. I ordered a 1 1/8" quite insert for the PC4, but they were on long back order and FMF cancelled my order. So, I welded up a baffle for my Power Core 4. I attached it to the 1 3/8" "quiet" insert that I originally purchased with my PC4. I basically kinda followed the post I found on this site. I welded 4 fender washers cut in half onto a steel bar, each one attached 90 degrees from the next.
It worked okay, didn't take much power away and at least I didn't feel like an open pipe Harley rider when putting around town.
Then last week FMF called me and told me that the 1 1/8" insert was back in stock. I bought it despite having a working baffle, just for comparison sake, and figured that they knew what they were doing. And I have to say it's quite a bit more quiet than the 1 3/8" insert. It is shaped different too. The 1 3/8" insert is pretty much a straight-through pipe with a conical screen spark arrestor attached inside of it. Whereas the 1 1/8" has a tapered tube that starts large and tapers down to the outlet. It has a conical screen attached to the inside end, and a single circular baffle plate with lots of little holes drilled into it right at the inside end of the tube.
The outlet opening on the 1 1/8" is tiny and it took me a while to get the allen screw started because I couldn't fit my fingers in there.
Also, the last time I had the can off, I packed it kind of loosely with stainless steel ebay packing.
