1973 450WR not shifting right
Good job sticking with it and figuring it out.
I had the same problem once, turned out to be my own doing.
I put a distance washer in the wrong place on the main shaft.
Glad to hear you got it figured out, and thanks for posting your findings. I'm sure your experience will be helpful to others.
I rebuild vintage Husky engines/transmissions. You can never be sure who has done what to these old motors, but after doing a bunch you get to know as you disassemble them, how things go back together. In most transmissions, there are only two washers that you can easily get confused about. One washer goes under the shifting barrel, and the other one sits on top of the shifting shaft. When you pull out the shifting barrel you don't notice the washer because it blends in with the case. But it's there. When I disassemble I make sure to put a zip tie on each component as well and on the ends of the counter shaft and main shaft assemblies so I don't forget. Another thing I have found helpful is to put all the transmission components in one baggie, the clutch components in another. Glad to hear you found the thick washer and replaced it and solved the problem. Both of these washers are the same thickness. Hope this helps.
