2012 te310 Sprag Clutch removal
Hello everyone,
I'm fairly new to working on bikes and just purchased a 2012 te310. Rolled it off the truck after I got it home and it had a gnarly backfire and sheared the woodruff key. After replacing it the bike started right up, ran for about a minute and then backfired again. The kickstart would not budge so I dug back into what the issue could be. What I have come to understand so far (and please let me know if I'm wrong) that the gear on the back of the flywheel contains a one way bearing that should allow it to spin separately from the flywheel in one direction. Mine is completely seized and shows signs of damage where it tried to rotate across the worm gear but clearly lost the fight. I've ordered a new oneway bearing but have no idea how to remove the gear from the back of the flywheel. Can someone help a brother out and point me in the right direction? Also, I'm aware I don't know all the proper names of the parts so feel free to correct a newby on what the actual parts are called in case I need to replace them. Thanks!
Nate
