Mike Mclennan
okay i did the same ride as I normally do, First gear walking pace for some of it hill climbs and the like, good recipe for overheating. 28 degrees C
I changed coolant to better quality, and got rid of the thermostat and got a copper pipe to join the rubber hoses, which didn't work as too close to the fuel tank but found some other hose that worked, and plugged up the other hose. The thermostat is fully integrated, so you can't just simply take out the thermostat bit as it is a sealed unit.
Anyways didn't have any issues starting on the ride.
So at this stage I have put it down to a faulty thermostat.
Hope this helps someone****************************************!!
I am still thinking of putting a fan on the other side for this kind of riding, good to keep things cool, and have already purchased a 220 CCA lithium battery to go in,,, as well as the spare temp sensor.
Michael.
Michael.
