2014 Husky TXC310
I have found that the easiest way is to remove the tank by removing the throttle body side fuel hose And leaving the hose connectes to the tank. Then when its time to put the tank back on, remove the hose from the tank and install it on the throttle body feeding it inplace and near where the tank elbow will be. As you lower the tank inplace, push the line on to the tank elbow. This is by far the easiest way i have found.
  • Like
Reactions: Jon
PS try undoing the QD at the fuel rail and leave the hose hanging off the tank, thats way the factory race team mechs always did it. I started doing it that way after seeing the CH Racing Team mechs do it that way, it's easier that fiddle ffing around between the tank and frame to release the QD at the elbow. (Metal elbow or not), Both my 310s had ZipTy elbows for bullet proofing anyway.
This is the way I did it anyway, hence I thought it was about the plastic elbow on the throttle body.
I noticed the connector for the hose is the same on both ends. I may try it that way. I stick a small wooden block under the back of the tank to free up my hands and made up a tool from an old pair of needle nose pliers. It works OK but, not great.
