Currently you must remove the drain back hose before adding oil. The new kit allows you to add oil without removing the hose.
No new kit because it is still being machined/anodized. I will work with 1st generation customers to upgrade their kits at a discounted price if they wish.I looked on the website and could not see the new kit, unless the change is not noticeable and it looks like the old kit. What's the difference, and can the old kits be upgraded?
Originally I thought venting the oil hose into the intake was a bad design solely for emissions, but if you ever went through deep water the hose is protected from sucking up dirt and water into the motor. At least the intake is sealed and protected and in effect becomes a closed system.
Keen for the new kit, I didn't get a reply for my order for the old kit and didnt end up chasing it up so I ended up making my own :P
My bike has a screen filter on the fitting that screws into the frame backbone. So the oil returning into the engine via the frame backbone does through a filter before getting to the oil pump, on my bike anyway :P
No it doesn't. The oil pump sucks from inside that screen (as if it were a straw), so the oil that is on the outside of the screen gets strained and then it goes to the oil pump. The stuff coming from the backbone goes straight through, not getting strained in the process.
Hey guys!
I`m not quite understanding this!
Why cant the rear drain with hose just be blanked off and only drain oil from the bottom plug on the 2013 TXC310?
Every 5th or so oil change the blank can be removed and the long metal filter can be removed and cleaned.
As stated,
On my bike there is a screen attached to the barb on the frame backbone catch tank, it filters the oil before running into the tube originally connected to the drain plug barb.
