430 AUTO, 4 gears and others PIZZA ( Bitza ?)
It would be nice if someone re engineered the first gear clutch and marketed it with cost more in line with chainsaws, jumping jack compacters, protable sawmills to think of a few that use this general kind of thing.
I don't know about the four stroke conversions the coasting and the saab three cylinder car with freewheeling is an attempt to deal with lubrication of a two stroke in the decelleration mode as well as winter conditions I suppose. I think adapting an oil filter would be something to consider. Is the four stroke using the transmission fluid as engine lube?
I got a picture of my mod to the kickstarter, this one is a later kickstarter than any of my auto's came with. This mod isn't needed on the standard shift to put those engines into the older single cam frame.
I also put an arrow at what surely must be an undersized bearing. Any one else have this one go bad?
The crankshaft come from a 500 wr or cr that has been recut to come into AE cases !
no Mike from my XC500 85
we planed the weights, the crankshaft 500 is 5mm wider than the 430
it has changed since these pictures
Now it is an AMX500LC mixed look 80/90 with a small Red alu tank 6L
jumbo Green went on a 84 AE250LC look 82
but still in box 3 speeds
