82 and up Engines in 1978 ML Frame Questions
It was included with the machine. When I have more money to play with ( after one or two are sold:( ) I would like to get a better TIG.
On my way to NH to pick up the welder I stopped at a bearing supplier to cross reference swingarm bearings and a variety of seals. For $48 I got (4) bearings for 1 swingarm, O Rings for (5) swingarms, and L & R crankseals for (2) engines. Seals for forks and wheels I will have to order. Definately worthwhile to cross reference for bearings and seals
Dad's came with his too, and he is a Mustang car guy so he never used it. A month or so ago I was going to weld an '82 Husky tank back there at the seat/backbone area where they wear/crack. For about 4 hrs I tried a bunch of different scraps of AL to practice on and it would just blob up or melt the AL but never bond as a weld.
If it was me i'd just extend the exhaust flange that bolts to the cylinder & then mess with the pipe, should just be able to just make an extension
like a muffler shop would do.
Husky John
I planned on extending the exhaust flange to meet the pipe rather than mess with the pipe. That is a perfectly fine 82 250WR exhaust and it has an 82 250WR it belongs to first. This is mostly a developement exercise to see what it would take to build this.
I read the instructions for the spool welder and on aluminum it says to use only pure Argon for shielding gas. Not Argon/CO2
One thing about the spool welder is that you have to use pure argon for aluminum and min thickness is about 1/8" If you tried to weld thinner aluminum with the 75% Argon/25% Co2 gas or straight Co2 gas it would likely sputter
