RTM
My 88 WR250 has spat it’s dummy and in doing so ripped the rim of the cylinder liner. I have obtained an 86 CR250 cylinder with piston I hope to be able to modify to fit.
In the photo it appears to have additional transfer ports but I’ll not worry about that.
I know the 88 has a 66.5mm bore x 70.8mm stroke and the 86 has a 70mm bore x 66mm stroke (roughly)
I plan on fitting the 86 liner into the 88 cylinder and seeing how things line up port wise modifying things as necessary (if possible)
Spacers / skimming etc.
Has anyone been here before and can give sound advise?
I know LA sleeve do a liner but its more than I paid for the bike, so failing the above I’ll be machining my own but want to explore the above option first.
