'87 CR250 Power Valve
I have asked for a full Circuit diagram, but I dont know if this is possible. If I get a good response I will post it here...
Andy.
400's already have a power valve... its on the right hand side of the bars and called a throttle!
im assuming it is stronger across the range as the std one is a nice tractor style power with a nice surge up top (not like mine! its a 125 on beta blockers)
I was told the other day that SEM made ALL of the parts for the Power Valve ignition system. No technical data is available (but I will consult a secret source next time I am in Sweden****************************************).
Andy Elliott
I was told the other day that SEM made ALL of the parts for the Power Valve ignition system. No technical data is available (but I will consult a secret source next time I am in Sweden ).
Andy Elliott
ah yes, the secret contact :cool:
sounds good all kidding aside
thank you for asking, in advance
I like that**************************************** If only the magnets were fixed in properly - that would be a start....
Andy
yep, I fell for that one as well. what a horrible noise... was sure the piston had shattered! pulled the exhaust off in the bush only to find it was fine???? was towed out of some steep country behind a tt600 Yamaha..not fun at all:eek:
