The 87 used a different left hand 40mm fork slider and a 2 spot caliper.
They also changed from a floating disk/fixed caliper to a floating caliper/fixed disk.
I have done this mod , 87 fork leg and a twin spot caliper with a honda wheel/ fixed steel disk , on my 86 wr and it stops like a modern.
All husky stuff won't comment as to why one would bother with honda wheels.
Fran
And strangely enough, I used to go riding around Warwick & Stanthorpe area.......I remember doing a 2 day ride called something like Brass Monkey ride, it was back in the 80's?......was loads of fun !!
I have a set of tripples the same as your lower picture but with straight up handlebar clamp posts , not laid back like yours.Here is a link to a picture of the two different triple clamp offsets I mentioned http://www.frannyk.addr.com/cafehusky/88and83orsotopclamps.jpg
I have bent the husky discs in the 1998-1999 wheels but they straightened out better than I expected. I had a pretty good guard on the 86 ae 430 and never bent the disc, did bend a rear sprocket though.
Fran
