metalhof
Feel like an amateur here...but I finished up completely restoring a '74 250 mag a couple of weeks ago. Since then, I have not been able to start the darn thing. Have pretty much (maybe) pinpointed it down to being a bad Motoplat, but not sure and hate to shell out the bucks if not needed. I have pulled the carb several times and recleaned, everything is good there, has all stock jetting. Seems to be getting fuel but not much on the plug after kicking extensively. Seems to get fuel if I open the throttle and overflow the carb with the Tickler. If I pull the plug, I get spark, but just seems like it's intermittent, and only really good spark with a really hard kick, but not every time. Was told this is typical of the Motoplat, but just doesn't seem right. In checking what I can check on the ignition, Im getting 300 ohms from blue wire to ground, 16 ohms between black and blue wire, and 6000 ohms from plug wire to ground. This doesn't match the readings that i've seen on some websites, but not too far off. Ive got compression (new rebuild), spark (intermittent), and fuel....but, not even as much as a fire, or an attempt to fire. Even pulling plug and dropping some gas directly on top of the piston, I get not even an attempt to fire. I double Checked the timing and it is set at 2.5mm from TDC, which should be correct. Am I doing something wrong, or am I missing something?? Also, with using the tickler, should the bing carb just dump gas right out the overflow and out the bottom of the bowl onto the freshly painted motor??? Seems like a poor design. Any ideas? Im getting frustrated and don't know where to go with this. As it sits, it pretty to look at, but not much fun!!!
