Timing is set as per manual. have verified.Sounds like it's way too far retarded.
Try setting the timing as per the manual and see how that goes.
Go to the website huskyjunk.com . Browse his array of billet and performance parts and this will become your dream list for your Mag as that is what he specializes in . A bit pricey but worth it . He has a complete Mikuni conversion kit with eveything you need , carb , manifold , airbell , etc. to just bolt it on and go . That is where I bought my triple clamps , billet extended clutch arm , and billet case saver , all of which I recommend . Great to deal with and quick to get your parts to you . I did my carb swap on my own and it was a lot of fitting and machining so the kit might be worth the $390 , GULP! .
Now the kicker issue . Yep you only get about one pop per kick . This holds true for even later models . If anyone ever devises a different set of gears to get more revolution per kick they will sell a trainload of them and become rich . If your clutch lever is adjusted really tight it CAN allow for slippage for the kicker . I always leave a little play in my lever , especially with my extended clutch arm . The extended arm makes the pull so easy that everybody who rides my bike immediately asks if the clutch is broken . It's about par with a modern KTM hydraulic clutch .
I have an Mzb ignition and it likes a lot of advance . Personally , I wouldn't be afraid to try advancing your ignition a bit from stock and see if it improves starting and performance . Just be careful of signs of detonation and overheating . You should be able to rotate the stator plate to do this but make sure you have good marks to go by to get it back to your original setting if needed .
I went through pretty much the same dilemma you are having and it was no fun , especially kicking my brains out , in 98 degree heat , on the starting line at Mid-Ohio , in front of a couple thousand people . There are solutions . Keep the faith until you find them .
Hi - I've been experiencing very similar problems with a 250 Cross (1967) that I've just re-assembled...What you explained makes perfect sense. That kind of fabrication work is "fun" to me. Ill probably start hunting ebay for a suitable Mikuni. My dad was at Forest's shop yesterday and talking to him about my kick starting issue. He said that the first place he goes with this kind of issue is a weak ignition. He said that they start to get weak, and require more RPM to generate sufficient spark than can be typically generated by kicking it. Rolling it and popping the clutch cranks it over at sufficient RPM to generate enough spark to fire. He was nice enough to give my dad a couple different stators and coils for me to throw on and try to see if this is indeed the issue!
Im glad you told me about the sprocket cover. I never thought about that...but I did notice that alot of them are chopped up into a small diagonal strip, and wondered why they did this! Seems obvious now!
