Check the Fuel Pump
Sam
HI,
first sorry for my bad english I´m from germany
I have a problem with my TE310`09, my dealer and I thinks the Fuel Pump (the pump wer is in the tank) don`t work the hole time so we think.
Do you know can I check the pump if it works normaly?
The Problem from the TE310 is that i have sometimes not the full power. It´s hard to describe it in englisch
Thanks Thomas
Fuel pumps usually work or they don't work ... They might stop and start a couple times but they usually just quit totally and the bike will not run in this case...
There have been reports of kinked or loose fuel lines inside the tank on the pump and sometimes the EFI needs a re-mapping to get the power right on the bike ...
Does your bike stop and will not start sometimes? Does it sputter when running? Bogging at low speeds? Has your EFI mapping been updated?
I'm sure someone here with an EFI machine can help with this issue ;)
You can check the fuel pump pressure with a automotive style fuel pressure gauge. That is if you have the correct fitting. I think it should be around 44 psi of pressure. That is what it is on a 2010 TXC/TE 250 anyhow. This will not tell you if the problem only occurs randomly. If you have the correct gauge you can compare it to another '09 TE 310. The service manual does not give these specifics. It says that you can bench test it and do not run it for my than 3 seconds dry. Also check all of your wires at your fuel pump to make sure they are not loose. Also I would completely drain fuel tank and add just a little bit of two stroke oil.
You can also get water in the fuel and it will seem like you're running out of gas. Plenty of gas in the tank yet the engine is sputtering at half throttle. This happened to me last week for a brief moment.
Although you could pull the unit and do the zip-ty fix....that alone may not be the problem.
Here is the fix.... http://www.cafehusky.com/forums/showthread.php?t=3355&highlight=zip+tie+fuel+pump
Good enough pictures so you don't need good English....;)
