I use Honda CRF friction discs with no problem in my 09 TE 450, drive plates will not work though, should be the same as 2010 TE450.I'll bump this topic if I can add same question for 2010 TE450, clutch plates, maybe Honda or Yamaha?
I think you want 08 CRF450, those are what worked for me, I am running a Rekluse but it uses "stock" frictions.That would be, say, a 2009 Honda CRF450, friction clutch plates?
(dang, bikebandit.com does not list having any clutch plates for any CRF 450
I really don't think so.Hmm...would they fit the 11 txc 250?
Since you have to order it anyway why not just order the correct plates from a Husky dealer? I would bet that Halls 217-789-0107, Motoxotica (707) 446-4282, or Bills (503) 585-1153 would have them. Why waste time trying to fit something that may cross fit when you can order the exact replacement just as easily.
In conclusion, if I can save major dollars OR have the knowledge that a part can be sourced locally, it's not a waste of my time to at least do the research to obtain the knowledge.
I'm running Rekluses in both my bikes, last time I ordered Husky clutches they where $200 for a set of discs and plates, I only need the frictions with my clutches. $200 for a set of frictions is robbery IMO. Honda frictions can be had for around $40 like mentioned above and are readily available. I really do try to support Husky dealers the best I can but $160 difference is huge, thats $160 I could buy 7602 stuff with.Since you have to order it anyway why not just order the correct plates from a Husky dealer? I would bet that Halls 217-789-0107, Motoxotica (707) 446-4282, or Bills (503) 585-1153 would have them. Why waste time trying to fit something that may cross fit when you can order the exact replacement just as easily.
I really do try to support Husky dealers the best I can but $160 difference is huge, thats $160 I could buy 7602 stuff with.![]()
. Honda frictions can be had for around $40 like mentioned above and are readily available. .![]()
Thank You!!!KG Clutch Factory Pro Kevlar Friction Disc SetPrice $84.95Component - Machine = 2008 Honda CRF450X
OEM Husky plates come as a set, friction AND steel, cannot buy frictions alone
$143
Thank You!!!
Price $84.95
$143
