Consequences of NOT replacing a TE449 crankshaft at 70 hours
Rob578:
I am in Victoria, BC, Canada. I've had two bikes stolen before, so I'm taking no chances.
Jose:
Thanks for the pics.
Not Chinese, Taiwanese made by kymco
https://en.m.wikipedia.org/wiki/Kymco
Those people make a lot of engines -
There are some growing pains when you first get your bike, these are the the must do's in my opinion:
Totally remove the fuel vapor catch assembly & plug the little hole that directs it back into the intake,
I took the crankcase breather hose off the air filter, plugged that hole into the air filter box, put a hose reducer on the end of the breather tube & routed it to a small catch bottle on the other side, during the break in it would blow by about an ounce every 9 hrs, after about 25hrs, no more blow by and catch bottle stays empty.
Lithium battery, way lighter & seems to eliminate the speedo reset problem, I think it takes a lot of cranking amps to turn that monster over.
Flush & replace coolant soon after you get the bike, you'll find some white powdery type stuff in the coolant, I think from engine assembly, replace coolant often - it's seems like a small quantity.
I replace oil every 9 hrs, again cause it's a small quantity, I use a k&p stainless oil filter, just clean with brake cleaner & put back in, I use the amsoil dirt bike 10/40.
I've replaced the rear wheel bearings 3 times since new, I think the seals & stock bearings aren't quite up to snuff. I got a second set of wheels from warp 9 & they are awesome.
If you can, pick up the fmf exhaust & you will need to go to race map II.
Once you get these little things sorted, these bikes are truly great, very forward thinking went into them & only now are other brands starting to use some of that same thinking, Yamaha for instance.
I've really only once used full throttle once, I ride mostly single track in waiporus here in AB, and my riding buddy said he saw the rear tire deform dragster style. I was going way too fast way too quickly.
View: http://youtu.be/-Yb5_rgrahs
