Yurii
Hello everyone. I didn't find a similar topic so decided to create a new one.
My bike Husqvarna TE449, MY2011, 2800 km (trail rides)
After a ride I have washed my bike. Everything as usual. Didn't put a lot on ECU and throttle.
Started the engine, let it dry working on idle and had a short ride to my garage where I stopped the engine and lubricated chain and linkage (approx 30 min engine was stopped).
Then I decided to start the engine but it didn't start: starter was working properly, it almost started but it didn't. It feels like air-fuel mixture is wrong.
All the time I have released the start button, I hear the sound during ~30 sec probably from working second throttle electric motor. (I attached video)
View: https://youtu.be/iF9iJk3uZFw
So I reset TPS as described in a relevant article. After TPS has been reset the engine started but hardly.I made a short ride around, everything feels ok, engine responded as usual, no control issues, but I found that after I stopped the engine the second throttle electric motor doesn't make a sound, that sound that we hear in ~10 sec after stopping the engine.
My friend advised me to check and clean all contacts, connectors, relays etc.
During the cleaning I found that SENSOR THROTTLE CPL, part number 8000H4737 (picture attached) is cracked and probably some water could be inside or whatever inside this body can be broken.
Now I'm going to order this part and replace it.
I need your experienced advice or any thoughts - could be a cracked sensor a cause of my issue and by replacing the unit 8000H4737 will I solve the problem OR I have to keep looking for cause of the problem?
Thank you in advance. Excuse me, so many text - I tried to explain and describe the whole situation
