Exhaust System Weights (especially the muffler)
My stock exhaust (2011 txc 449) is huge, weighs a ton (guessing 8-10 pounds) and stays hot for at least two hours! But it's quiet, which I really like. So what do I do? Can't afford Akro but love that one. Looking at FMF Powercore with Quiet Insert, but I'm afraid it will still be way louder than stock.
I have the powercore with the quiet insert. It is really loud. I remember that someone on here could net even pass the 96 db test with it and had to put on the stock can for the test and then put the powercore back on for the race.
Oh thank you, thank you. I was thinking this and started to drill out the pop rivets. They seemed to be hardened steel. My drill bit won't cut beyond the aluminum collar. I guess I have to find a better drill bit set. I'm excited to give this a try.
Try using a small drift punch and knock the hardened steel center through the rivet then drill the head off. I spent several years working on aircraft back in the 80's (8 years Navy) as a structural mechanic. We didn't use many pop rivets in those days but did come across them and had to replace them enough to get good at it.
stainless rivets= less likely to work their way out like aluminum.
But hard to drill as well- use new bits- use a drill press if available for consistent pressure and accuracy. (this decreased my drill time by 2/3 of the time)
