If you're going to race it, I would. I would also consider a power-commander 5 in conjunction to that.
Butterfly is removed. Damn......they must of used little elves to put motor, wiring and air box in!!! Will the EFI adjust for butterfly being gone? Power Commander looks nice but I'm going to try the JD programmer again and see if I can get it to work right. Any idea of HP #'s on the TXC 449? Any idea what top speed of these bikes with 15/49 gearing is? Can't wait to get this bike in the dirt!
Tinken.....how do I get the last .150 of oil in bike? I was able to get 1 full quart in motor but it was topped off.
Thanks!!
Thanks!!
Efi does not compensate for the in rush of air when the throttle is snatched open. JD tuner will help a lot (not to sound like I'm overly pushing the pc5, Motomummy has a good deal on them), but the JD is unable to fully tune like the pc5. Hp depends on exhaust, air box, fuel metering. For the oil, I measure out 1200-1300cc's. On the kick stand, I fill to the top of the threads. Start the engine for 30 seconds and fill the rest. The oil galleries hold between 250-300cc of oil. Stainless steel oil filters are a big plus. I'm working on a TL fix as well.
Should I do the butterfly removal dealchi city ???
Should I do the butterfly removal deal???
That's a good location. I also opted to mount mine where I could tweak it while out riding. So I put it on my handlebars mount bracket. There were several times where I stopped on the trail within 5 minutes after starting for the day to make adjustments. Usually this happened when I fiddled with stuff at home, 500' elevation, that effected airflow then trucked the bike to the trails at 2500' elevation. If it was under the seat, I probably wouldn't have made my friends wait for me to pull the seat and make some adjustments.I mounted mine on the back of front number plate so i didn't have to remove the seat to access it while riding.
