Here is something to think about ! Gas is worse than I thought !
You are correct that Sea Foam contains alcohol but it is not Ethanol but rather Isopropyl which has a larger molecule (Methanol is CH4O, Ethanol is C2H6O and Isopropyl alcohol is C3H8O) so it still serves as a good solvent but is less likely to permeate rubber and soft metals like aluminum. If it doesn't permeate them then it wont leach out any of the those elements that make all that nasty stuff in you're float bowl.
Seafoam works.
And people should avoid putting dihydrogen monoxide in the fuel. :D
Sta-bil also has isopropyl alcohol, it is used to absorb water and put it in suspension with the isopropyl molecule where it can be burned harmlessly.
Interesting little Husqvarna bit.
We [ me and a mate ] have been buying 86/87 WR400 heads out of USA to fit deco's to.
The USA heads have a lot higher comp ratio than the heads fitted to Australian bikes.
Maybe the fuel over there was a lot better than Aust fuel in those earlier days.:thinking:
Not sure about Texas but there are many places here that still sell non ethanol gas. Might search around. Also I would not leave any steel or aluminum tanked bikes without gas in them for any length of time.
I 'coat' the inside of my metal tanks with 2 cycle oil, I also use non ethanol gas. The ethanol was destroying the fiberglass on my Bultaco
