Husqvarna wheel lacing instructions
Watto please tell us about your re anodizing of the Nordisc. My experience is that they will spilt open at the weld if left unlaced for a nanosecond....well after a few days at least. How did you tackle it and what did the colour come out like? I am after all your secrets!
Most of you do not seem to know that there is only a 50% seam weld in the manufacture of these rim. The rim is in no way impaired when the unwelded ends of the seam separate from a heating process or from a perfectly timed and place hit to the ends of the seam from riding.
Yes, exactly that happened to my front wheel...I pulled the wheel apart....then a couple of days later noticed the seam had come apart... anyway..... made the bracket in the pic... bolts together 4 spoke holes.. "v" out the inside of the rim and weld...do not weld the face of the rim.... as fas as the re-anodising.. well.. as our French friend suggested in his "Black is beautiful".. I sand blasted the rim..then cleaned it up with a small plastic wheel brush that fits in a hand held drill... the polished on a bench grinder with a rag mop wheel and bar of paste polish..got reasonably happy with the shine..off to the anodiser....he wasn't really thrilled about doing the job... oh.."if it is 7000 series alloy wil come out blotchy.....blah..blah....took two weks to get it done..he had to remove the rest of the old anodising in a acid bath as the sand blasting did not remove it all... in the end .. I was pleasantly suprised with the colour match.. I had a sample 84/85 rim for him to get a colour match... cost me $100 per rim...which is pretty expensive...but... they don't look half bad now...
You could contact them.. money talks I guess.. guys name is Brian.. Camera Dynamics in Landsdale , Western Australia.. (08) 9302 1316..don't forget the time diff..;)
