Caiman
Senior Vice Procrastinator
I noticed on mine that it was hitting the blinker/horn switch block when pulled in, my thinking was that the KTM's run a thinner width switch block so the bend in the lever clears, where as it fouls on the husky's so can't fully disengage the clutch, hence the creep. I loved the low effort of the MME lever but setting it right, the change in span between cold and hot engine and the fouling pissed me off enough to switch it out for an ARC clone lever.
Brake side I run a Brembo RCS15 master cylinder (supermoto spec) so can't comment on the brake lever.
