fran...k.
As to that shift return spring which looks like a circle of a couple of winds and two perhaps two inch more or less straight ends, it can get bent if the clutch cover isn't put on right. It kind of straddles a pin. I acutally bent it this year for the first time and just re bent it. My symptoms weren't first and second gear only but if it is the spring you should be able to re bend it, I did.
As mentioned prior, the little pins used to turn the shift drum can get worn or deformed. When I had my engine apart this winter I couldn't get the bad pin out and swapped the whole drum. Do I understand you can manually turn the drum somehow and shift through the gears? I really doubt wobbly shift lever, the one the foot actuates makes a difference.
fran
fran
