My Motorcycle Thead
Yeah that's an amen savior frame American metal engineering. I believe it stands for little bit of a spring on the top, even less spring on the bottom with my fat ass. They're both screaming at the same time hahaha
The 78 triumph chopper needs a sissy bar and suicide shift. And how the heck are you going to start it with your knees falling apart?
Actially since iam working for myself
My knees seem to be healing
Do they hurt sure
But not like they used to
Try to get them rested and iced when needed
Car show today
Looks like it kissed the pavement at one time. Sounds good, I like the quick revs. Sounds like it'll capable of causing the rider to unleash a whole lot of feel good hormones.
So I bought a Nice original Kawasaki by Kerker Chrome Header because I did not like the black painted one with the slipon muffler.
And
It don't fit. :eek:
Turns out the mounting lip on the old one is about 1/4 thick and the new chrome one is 16ga. so you can not tighten the header to the head by a bit! The split collars are short by 1/8"+.
Dang!!! If I add to the header it has to be air tight, so I have the crusty rusty split collars from the Z1-R but it is 1000cc so the collars are larger. So I took one and cleaned it up on the wire wheel and put it in the vice and crimped it a bit until it fit in the split collars clamping flange. OK We are moving, then I checked the crimpage to the pipe! OK Moving on the split collars are now touching each other and require trimming to get them to stay in the flange and close on the pipe as they sit in the well of the exhaust port and there is no side Clearance Clarence!! So a bit of time on the disc sander and DANG!! It Worked!! The Pipes seal on the exhaust port and there is enough room to tighten them against the crush sealing washers!!
Sweet!!
The bike Sounds Awesome and the Exhaust Looks Wonderful!!
After reading and looking at the pics I saw the HUGE GROOVE in the Swingarm.
Looks Like the previous owner was a amazing mechanic!!
I mean How Much Noise Did that Make every time the suspension compressed!!! DANG****************************************
I will Grind and Weld that up tomorrow.
But What the F.........
I saw in the first set of pics that the swingarm was being sawed in half and also wondered WTF. Maybe the previous owner thought it would soon stop cutting and everything would then be okay. :eek:
