mancave
Okay, so this is my first at posting anything on cafe husky (so be nice) I am by no means a mechanic but learning as I go...
I recently purchased a 76 WR250. Bike was not running when purchased. No spark, so found that problem and after many many kicks got her started. Bike would run but when you let off the throttle it would die.
Had a replacement carb on it Mikuni looked new, thinking the low speed jet may be clogged took off, cleaned (though looked great) put back on, same problem. Adjusted the air screw (several settings) same problem... Had the original carb, so cleaned it and put it on the bike, same problem. Very hard to start and as soon as off the throttle she dies.
So now thinking the carb may not be my problem. Question, does this sound like a low compression problem? I can tell it does not have great compression from the kick (also have 77 CR250 and much harder to kick)... Any suggestions would be appreciated. have never tried to replace rings or a top end but with your help, sure I can do it.
Thanks!
Thanks!
