nonson
Hey everyone. I picked up a 2011 TE310 a month ago with about 2000 miles on (hard miles from the looks of it) and I've basically been fixing little issues nonstop ever since:
Question: Why me?
Real Question: Today I was in stop-and-go traffic and I had been riding for about an hour with no problem. Accidentally hit the kill switch so I kicked it over again. Started up and then crapped out right after. Tried again, same thing. Felt like it wasn't getting fuel or something - struggling to stay alive. I pulled over for a few minutes and let the bike sit, inspected it and didn't see anything obvious. Then I started it up again and it seemed everything was fine.
What happened?? Could it have been overheating in traffic in 80+ degree weather? I know temp sensors on these bikes are wonky too, but I didn't hear any popping from the engine, so I really don't know and it worries me. The last thing I want is for this thing to strand me like it has threatened to so many times already.
Sorry, that's long winded but it has been endless maintenance with this bike since day 1 and I had to vent. Do you think I'll ever feel like I can trust this little bastard? I love it when it works, but the moments of joy have punctuated by frequent moments of unreliability that I haven't experienced on a bike before. She hasn't won my trust.
Thanks!
- Positive battery lead tore loose - a side effect of poor battery placement design I assume.
- Chain tension adjuster bolt seized and I spent 3 days drilling it out.
- A head scratching bogging issue that was caused by the fuel pump coming loose from its holster.
- Headlight blew out both high and low beam within a day (no big).
- Chain snapped off (happens) and I pushed the bike home
- Had the starter issue that is apparently very common. Worm gear shaft and ring gear are chewed up. Couldn't even kick start because it was binding up and trying to spin the starter motor, so I suspect sprag clutch as well? Husky says they're not covering it since the bike isn't under warranty anymore...even though it's a design failure?? Ok, anyway...I hacked off the worm gear (because it was stuck and I couldn't remove it for some damned reason) and have been kicking it since.
Question: Why me?
Thanks!
... No clue but others here are on the inside of that saga and should provide you some guidance.
