Not really. The Auto Tune works quick enough - though there are settings to adjust how fast and how much those are adjusted....I guess the autotune unit would improve that but it'd take a lot of riding to get a well tuned map using the AT alone.
Let me guess, Ty Davis is now a Dyno Jet dealer......I'm sure Tinken could shed some light on this.
Notice the green bar graph on the right of the monitor in the vid, that's your air fuel ratio. When the graph is inthe green your at the best balance . A power comander dyno tunned right will keep it in the green all the time. When the graph dips into the yellow it's lean, blue rich. If you want to spend 3 times the money go for it![]()
Pcv + at is a awesome unit ! The JD is more for guys who have a good understanding how to jet carbs. . There is a element of guess work with the JD tuner . The only way you can jet a bike or program the EFI to the nats ass in with a dyno tunner. A great feature with pcv is you can carry 3 programs. Good thing about JD is I can tune on the trail, I can go from 0-10,000 feet in elevation and the stock ECM will correct my air fuel ratio automatically , you need to flip to a different program on pcv. Also pcv is expandable for all sorts of add ons like auto shifts, clutchless up shifts, it really is the shit. But for me $189 and a $100 tip to a friend with a dyno tunner works good enough. My bike has gained a hugh amount of power compared to stock. The best gains you are going to get for the money is in intake, exhaust and JDHow else are you going to properly manage fuel delivery on this bike? PCV+AT seem to be the only way.
No prob , have fun with it ! I can do full blown wheel stands starting over 70 mphIntake and exhaust are in the works. I had a JD tuner, but sold it before even trying it. This is a commuter/fun bike only, so I just want to keep it simple, even if that means spending a bit more money. You are looking at $300 easy to have the JD and a dyno tune. Typically more since I don't have a buddy with a dyno. But we will say $300 for simplicity. For me, the PCV is $299 adn the AT is $209. So I spend an extra $200. I will cover that cost very quickly in the time I could bill for consulting versus hauling my bike over to a tuner and waiting for a tune. After this thread, it is a no-brainer for me to just get the PCV+AT.
I appreciate the input.
No prob , have fun with it ! I can do full blown wheel stands starting over 70 mphget a bunch of thumbs up from the drivers on the freeway too ha ha
Personally, I think that is a positive....The negative to the autotune is to make it work best you need to check up on it with a PC while it figures out the new tables. For instance, the autotune is limited to a 20% TRIM adjustment, and my bike needed more than that in some cells, so I needed to ACCEPT the 20% and let it adjust even more on top of that. ...
@Coffee: You are correct, the 20% limit is a good thing! I just meant that the negative was the need to understand the software and use the pc several times. In many cases (those that will require significantly more than 20% trim from the base map) you can't just plug in the AutoTune and forget it if you want optimal tuning.
I'll add another note. The trims I have ended up with almost seem to vary without reason. I mean some cells will be up and others down in relatively close proximity on the map. If you graphed the map, it definitely wouldn't be a smooth wave. If this really is optimal, it would indicate that the other tuners that only allow a crude adjustment of say the low, high and mid ranges are possibly really missing out. Alternatively, it could just mean that the map is pretty variable based on every ride and the conditions at the moment, and maybe the last 10% differences in those cells doesn't matter.
Thanks man. My 511 is the SMR . I just want it to purr as smooth as it can.
I did.... you don't get to high RPMs with a small throttle opening, so that part of the chart stays pretty empty too.
