Bugsinteeth
Good day folks. I’m hoping some experienced folks can chime in on a problem I am having with my clutch.
Bike: 2008 Husky TXC 450
Symptoms:
From stopped, when taking off at a normal pace, I reach the clutch engagement point and it is super flakey. It behaves like the clutch is partially disengaging and engaging rapidly . This results in uneven pull away from stopped, much like jackrabbit starts of a person learning to use a clutch for the very first time. This condition is only felt from stopped, 2,3,4,5 shifts no problem. As bike comes up to full operating temperature the problem goes away???
Background:
Low hrs. Bike bought recently with 35 hrs. Currently 80hrs. Just returned from a Baja trip of 2500 km where a buddy was riding the bike. I was on the trip so I know he struggled in the tough stuff. Some clutch abuse was likely involved. Buddy says clutch worked flawlessly throughout the trip. No issues.
Post trip I did regular servicing oil/ filter ect. No weirdness/surprises. I decided to install an Oberon clutch slave cyl as a preventive measure and set aside the stock magura as a spare.
Problem starts. I assume I have done a poor job of bleeding out air from system and proceed to bleed several times. Top down (conventional) and bottom up with syringe. Always get nice firm lever but problem remains. Thoroughly clean/ dry/inspect all components master/line/slave to check for leaks. None found.
So:
Do you think my problem is with the hydraulic actuation system? OR Is it something internal in the clutch?
Anyone else have difficulty after installing an Oberon slave?
Is there mystery spot where air collects in the hydro system that requires a special bleeding technique?
Has my buddy rooted the clutch plates ect. During his struggles in some fairly harsh Baja single track?
If clutch pack disassembly is recommended, what signs should I look for to indicate damage?
Many thanks for your help with this.
Bugs.
Symptoms:
Background:
So:
Bugs.
