Problem with flakey clutch on my TXC??
Thanks for this info, im having the same symptoms on my 08 tc 250. Suspected the springs since i could see the clutchplate not lifting evenly when pulling in the clutch with the cover off. Though all the springs still measured the same.
Installed new oem springs today, fixed the problem for me too. Plate now lifts evenly and clutch engagement is smooth when cold.
Yep definetly, so I should add for any future readers that the spring change actually didnt cure my problem completly. My last post was after a quick driveway test only, turns out the clutch was still jerking when cold, although it was not as bad. I then tried to sand both the friction plates and steel plates after reading it on thumpertalk i think, going light on the friction plates ofc, and that seems to have done the trick. Couple real rides now and the clutch is still good.
Hm, wasn't aware that there was rubber there, eitherway my symptoms were jerking and grabbing on off when engaging, and not play in the driveline really. But thanks anyway. Also flushed my clutch fluid today, must have been the original from 08 in there lol, shit was like muddy water out of a pond. Improved the clutch feel further, couldnt be happier with it now!
Nice! Didn't know it got 'muddy' but knew the fluid picked up moisture which made it 'squishy'. :)
