Race Map 3 or JD Power Surge 6X
This is the double bend I made the hose from the vent to the oil cooler.
Holds its shape and I can still get to all the bolts when required.
C:\Users\Bob\Desktop\hose_1
Hi Cosmokenny, I took some pics of how I was told to bend hoses WITHOUT kinking them.
Choose a spring that has a slightly larger (or at least the same) outer diameter as that of the inside diameter of the hose that you need to bend. NOTE: the spring may not have a smaller diameter than the hose.
Preferably choose a spring with end rings/loops because springs slightly too large need to be pre-stretched a little. After stretching or if the ring does not need to be stretched cut the end rings/loops off.
Thread a nylon cord (cotton cord does not slide as easily) through one end of the spring and double it over.
Then feed the two lengths of cord through the hose intended for bending until the cord appears out the other end.
Then pull the two lengths of cord thereby pulling the spring into the hose, feeding it slowly as you go (I found lubricating the inside of the hose with a little oil helps).
Pull and feed the spring slowly into the hose until the spring is seated in the hose where it will be bent.
Insert an additional spring for each additional bend...
That's a great idea! Thanks for the post.
